22 April: AR 12816 / 12818 in H-alpha and CaII-K.
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Hi Everyone.
Managed to capture some higher resolution images of the two beautiful active regions. The H-alpha images were shot at approximately f/27 with the C8 Edge while the Ca-K images were shot at an outrageously high ~f/55 with my Stellarvue 115mm APO refractor. I had been playing with some high magnification optics configurations during my last Ca imaging session (last year) and forgot to reconfigure to more "normal" values before yesterday's session! Oh well, the results aren't horrible but do lack some sharpness and I would have preferred a more expansive image scale.
Mark: You asked me, in a previous post, about collimating my C8. I'm embarrassed to say that I haven't collimated since I bought it a few years ago! It's high time I check it out. Also, you asked me about image shift during focusing. I don't use the mirror adjustment for focusing but have a Moonlite rack and pinion attached. Very smooth focusing.
Peter
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Re: 22 April: AR 12816 / 12818 in H-alpha and CaII-K.
Post by Ivan »
Fantastically beautiful photos, I especially liked the second one.
p_zetner
Post by p_zetner »
Thanks, Ivan.
It’s my favourite as well because the AR is beautifully complex and because it was imaged at the beginning of the session when there seemed to be more frequent intervals of reasonable seeing.
Peter
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Thank you Peter for sharing you excellent framed images
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Cracking Ca II K images, Peter. Very nice indeed. As you say, AR12816 is quite a complex system.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Excellent images Peter.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 9292 times
Been thanked: 6127 times
Post by ffellah »
A great set, Peter. That 115mm APO rocks.
Has thanked: 17807 times
Been thanked: 16944 times
Post by DeepSolar64 »
Very nice Peter! Both on Ha and CaK.
p_zetner
Post by p_zetner »
Thank you all for the generous comments! Still waiting for an “excellent seeing” prediction from Astrospheric to try to nail the high resolution imaging.
Franco: The Stellarvue 115mm f7 is a great refractor. I love it for nighttime visual sessions which I can do at a less light polluted location. I would like to switch over Ca imaging to my Istar 100mm f12 and will test that out hopefully this summer.
Peter
Has thanked: 20738 times
Been thanked: 10435 times
Super shots Peter, a 115/7 is on my (long) wish list of scopes. It's surprising how much the f-ratio can be pushed with CaK.
Reason I asked about collimation is I tried my HaT the other day when was clear and the view was awful, i'm thinking I need to collimate mine too. I have dawg awful image shift with it when focusing so will look to use my Moonlite focuser on it instead.
