Belated CaK and WL from 22nd April
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, just managed to process some of the images from the 22nd April. 100mm Achromat plus Lunt b1800 CaK and 80mm ED pluse hershal wedge and baader K-Line filter for white light.
- 20210422-103159UTellabryant-AR-WL.png (2.73 MiB) Viewed 220 times
- 20210422-103159UTellabryant-AR-WL-col.png (6.72 MiB) Viewed 220 times
- 20210422-101332UTellabryant-FDWL.png (1.97 MiB) Viewed 220 times
- 20210422-101332UTellabryant-FDWL-col.png (5.56 MiB) Viewed 220 times
- 20210422-100347UTellabryant-CaKfd-invert-col.png (4.87 MiB) Viewed 220 times
- 20210422-100347UTellabryant-CaKfd.png (2.64 MiB) Viewed 220 times
- 20210422-100007UTellabryant-CaKfd-proms.png (2.94 MiB) Viewed 220 times
- 20210422-100347UTellabryant-CaKfd-col.png (5.82 MiB) Viewed 220 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17581 times
- Been thanked: 16698 times
Re: Belated CaK and WL from 22nd April
I love the inverted CaK image! Nice! Though the amount of detail is significant in your WL images it looks like seeing is obscuring the very finest of detail. That's normal here for me.
Large files...
Large files...
- Stardust5858
Thanks James, I'll have to start saving files in jpeg in future. Seeing wasn't the best but not as bad as the 23rd. I was to late in the morning and temperatures had risen significantly. My best time is between 8am and 10am.DeepSolar64 wrote: ↑Sat Apr 24, 2021 12:49 am I love the inverted CaK image! Nice! Though the amount of detail is significant in your WL images it looks like seeing is obscuring the very finest of detail. That's normal here for me.
Large files...
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4787 times
- Been thanked: 10248 times
Good shots! JPEGs would be good. Looks like you were fighting the seeing. Run that 100 achro at 60mm with your CaK and will give you considerably better results...
- Stardust5858
Thanks Maurits, appreciate your comment.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Mark, yes I was fighting seeing for the past several days even though it's lovely and sunny. I had the 100mm stopped down to 80mm but think I could have still reduced further as you say. Typical, lovely clear blue skies and horrible seeing.marktownley wrote: ↑Sat Apr 24, 2021 11:01 am Good shots! JPEGs would be good. Looks like you were fighting the seeing. Run that 100 achro at 60mm with your CaK and will give you considerably better results...
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
If you're just doing full disks, at that scale, reducing down to 60mm (good seeing!) all the way down to 40mm (less than ideal seeing!) work well with CaK. I even have a 30mm mask for diabolical seeing. Don't forget in CaK you have 1.6x the resolution of Ha because of the shorter wavelength, so 30mm CaK is the same as 50mm Ha... 80mm CaK is equivalent to 130mm in Ha...Stardust5858 wrote: ↑Sat Apr 24, 2021 11:09 amThanks Mark, yes I was fighting seeing for the past several days even though it's lovely and sunny. I had the 100mm stopped down to 80mm but think I could have still reduced further as you say. Typical, lovely clear blue skies and horrible seeing.marktownley wrote: ↑Sat Apr 24, 2021 11:01 am Good shots! JPEGs would be good. Looks like you were fighting the seeing. Run that 100 achro at 60mm with your CaK and will give you considerably better results...
- Stardust5858
marktownley wrote: ↑Sat Apr 24, 2021 11:16 amIf you're just doing full disks, at that scale, reducing down to 60mm (good seeing!) all the way down to 40mm (less than ideal seeing!) work well with CaK. I even have a 30mm mask for diabolical seeing. Don't forget in CaK you have 1.6x the resolution of Ha because of the shorter wavelength, so 30mm CaK is the same as 50mm Ha... 80mm CaK is equivalent to 130mm in Ha...Stardust5858 wrote: ↑Sat Apr 24, 2021 11:09 amThanks Mark, yes I was fighting seeing for the past several days even though it's lovely and sunny. I had the 100mm stopped down to 80mm but think I could have still reduced further as you say. Typical, lovely clear blue skies and horrible seeing.marktownley wrote: ↑Sat Apr 24, 2021 11:01 am Good shots! JPEGs would be good. Looks like you were fighting the seeing. Run that 100 achro at 60mm with your CaK and will give you considerably better results...
[/quote.
Thanks Mark, I'll have to get busy and make a 60mm mask.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Excellent/Fab set of images Nigella.
The negative-CaK image does add to the result of the positive-version so well.
Thanks for sharing
Thanks for sharing
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Beautiful set of images!
Marios S.Ioannou
Sketcher/Visual Observer
