So, I had to throw the setup together, find an interesting target and get recording as clouds were starting to roll in, so orientation is likely wrong and I don't remember which sunspot group I imaged either, but at least I barely beat out the clouds, lol. Lost the last 3 videos of the series to clouds, but I'll take what I can get. Also tried not to blow out the highlights, but failed on that front. I'll leave a touch more room at the end of the histogram in case things get brighter later, as they did a bit on this one. I'm always a little overly optimistic on just how much magnification the seeing can support, so once again if you squint your eyes things clear up a bit:)
Lunt 100 with asi294mm and 4x telecentric, ROI of 2200x1380ish
Quick animation of small sunspot group
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Been thanked: 4787 times
- Been thanked: 16694 times
Re: Quick animation of small sunspot group
That is amazing!
- Been thanked: 10247 times
Nice ani!
