Quick Ar12818 CaK - 24th April
- Been thanked: 10248 times
Been far too busy for the last week - making the most of the last of the Easter holidays, and then back into work at 100 miles an hour has meant just not having the time I like to get on here and see everyones images. Needless to say I was pleased the weekend had arrived... Today was forecast to be clear skies, however i'm often in disagreement and my own forecast was for haze and high cloud, and this is what I got. I managed to get a quick look before the 'soup of the sky' was just too thick to do anything.
I was keen to try out my new ZWO290mm, which i'd bought specifically for CaK, my theory being those small pixels do away with a barlow for image amplification and overall there is more light for the system. Initial results (and was playing around last week with the travelling kit with it) suggest it is quite a sensitive camera in CaK and holds much promise. Seeing wasn't great this morning and I optimistically started off at 120mm aperture, this was mush on the screen so started to stop down. I have a series of stop rings from 120mm all the way down to 40mm for the 127/1200, and when you hit the right aperture stop for the conditions it's really obvious and the view snaps to focus. DEspite the haze today softening things up quite a bit, i'm pleased with this result. Works out 90mm f40 with the 290mm, very much an oversampled image, but it shows potential, the fibrils in the penumbra are just starting to resolve.
ar12818-CaK-90f40-290m-bw by Mark Townley, on Flickr
Running this system at 120mm when seeing allows would give me f30, and quite a decent step up in resolution. Hoping the cloud / haze band passes over later in the afternoon so I can see what's going o in Ha, the sun is picking up in activity nicely. Hoping tomorrow morning offers better!
- sulcis2000
- Has thanked: 2 times
- Been thanked: 477 times
Re: Quick Ar12818 CaK - 24th April
Excellent image!
Alessandro Bianconi
________________
Celestron C14HD Edge
Celestron C14XLT made in USA
Refractor 228 F8 Truss Tube with D-ERF 110mm
Sharpstar 76PHED
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
Basler Aca1920-155um
ZWO ASI462MC
Celestron Skyris618M
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
Thanks Ale!
Yes Mark that certainly is an excellent capture for Cak.
Thanks for sharing
Regards
Thanks for sharing
Regards
Thanks Terry, hoping the milky white haze I have right now will clear soon so I can get a second round of images in today.
It does look from the weather-satellite imagery that the Sun is burning-off some of that haze layer in your area and hopefully you get the very-clear views soon...
Regards
Regards
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely capture Mark, seeing was bad here again. Not processed any yet but expecting the worst. I'm going to have to build a series of aperture masks. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4787 times
- Has thanked: 17581 times
- Been thanked: 16696 times
Very nice Mark. Those stopdown rings would be handy.
Thanks everyone, stopdown rings rescue many an image when the conditions don't support the native aperture.
This is the only other usable image I got from today; haze didn't clear till late afternoon, by which time the seeing was absolutely sh!te... Taken wit a Lunt 50 etalon, cemax 2x barlow and the ASI290m camera.
Ha-swathe-ss50-290m-bw by Mark Townley, on Flickr
Ha-swathe-ss50-290m-colour by Mark Townley, on Flickr
Hoping tomorrow morning is clear and seeing is half decent as want to try some more CaK with the 290...
It looks like we have a new spot group developing near AR12818!
Yes that's right James and only a few hours ago was quite different.
So this new-set near AR2818 is apparently AR2020 and looking very impressive as it has grown so much.
In fact with the close proximity to AR2818 and 2020 consisting with as many as 11-spots, I wouldn't be at all surprised if a massive flare/CME might occur sooner or later...
And of course Mark, some more extra excellent captures...
Regards
Regards
- SDO_HMIIF_1024.jpg (102.12 KiB) Viewed 536 times
- 24-4-2021 2153z latest_512_HMII.jpg (27.39 KiB) Viewed 536 times
I saw not a trace of AR12820 in yesterday's session. Only the single spot of AR12818 nearby. Change rapidly the Sun does....
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
Both images look great!
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
Thanks guys! Hoping to make the most of Sunday if these pesky clouds shift...
- JochenM
- Been thanked: 1619 times
That came out great, Mark.
The ASI290MM has been my go to for CaK closeups for a while as well, works very well (and the high framerate also doesn't hurt).
Thanks Jochen, I agree, i'm very impressed with it so far.
I also found a CaK FD I took, 50mm f20, a bit soft, I think 40mm f20 would have worked better but i'll take this given the soup I was trying to work in yesterday afternoon...
CaK-FD-bw by Mark Townley, on Flickr
CaK-FD-colour by Mark Townley, on Flickr
- Been thanked: 2713 times
The first Ca K image has a lot of potential. It will be great when seeing cooperates.
For FD images, 40 to 50 mm aperture is probably close to the optimal given the sensor size.
Processing is perfect !
- Has thanked: 9145 times
- Been thanked: 6025 times
Lovely images Mark. Like Christian said, processing is perfect.
- Been thanked: 4340 times
Excellent images Mark
The 290 is a great chip!
- Been thanked: 4904 times
- solardave
- Has thanked: 10 times
- Been thanked: 219 times
nice images mark
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Excellent result Mark and thank you.
Marios S.Ioannou
Sketcher/Visual Observer
Thanks everyone for all your kind words!
