Visual Report 24/04/2021
AndiesHandyHandies
Has thanked: 3292 times
Been thanked: 1887 times
Post by AndiesHandyHandies »
127mm F7.5 Triplet 2" Baader UV-IR 4.2x Quark Chrom Clave' 25mm
Sunny, light cloud, still. Observing later over town.
I am left right reflected to gong.
3.20 BST
5.00 Large prom from yesterday. A bright prom leaning up. Dim little supportinh arch under. Dark gap.
Another bright prom leaning up. Above that a dark upside down comma leaning up/right.
The two merging at the top.
Broad striated prom above the comma leaning up. With a dark sqiggle under leaning up.
Going behind another striated prom leaning down. A dark dot at the underside where they cross.
A dark gap with dim connectiona at the top.
Above a little bright shark fin. Dark base at the lower end.
11.00 4 jet prom.
Support small jet leaning up to fitst jet.
Second a thin jet with pyramid on top. Fuzzy area to left of the jet.
Third jet with bright top leaning over second jet.
Fourth jet above leaning left.
Whole with a rounded top.
3.00 Array of fine sprays. Arch prom below with pyramid bases.
4.00 Little pyramid.
Pair of sunspots.
Left has dark dash to top right. Little jiggly dark line going down, jigs right and down. Left of that 'wire coil' going to other leg. Below right two bright inverted quotes with dark line to bottom sde of each.
Right spot looks a solo feature.
Cheers. Andrew.
Has thanked: 20435 times
Been thanked: 10245 times
Re: Visual Report 24/04/2021
Glad you got some viewing in Andrew!
Has thanked: 17572 times
Been thanked: 16693 times
Post by DeepSolar64 »
Thanks for the visual update Andrew. Clouds and rain had me out of action today. :(
