Hi Guys
Nice and sunny today albeit really high cloud that made focus soft and wobbly
I took a few images and have added some of my gear for fun the adapter for my Quantum arrived today so I can control it from the PC
Hope you like them
Rich
24-04-2021 High Cloud but Good Day
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
- 2021-04-24-1445_ Prom ASi174 DAystar Quantum SE.jpg (53.96 KiB) Viewed 260 times
- 2021-04-24-1430_ Prom Daystar Quatum SE ASi 174.jpg (71.56 KiB) Viewed 260 times
- 2021-04-24-1410_ AR2818 ASi174 Daystar Quantum SE.jpg (467.75 KiB) Viewed 260 times
- 2021-04-24-1355_ AR2816 ASi174 Daystar Quantum SE.jpg (326.62 KiB) Viewed 260 times
- 2021-04-24-1345_ Prom ASi174 DAystar Quantum SE.jpg (36 KiB) Viewed 260 times
- Solar Kit .jpg (62.06 KiB) Viewed 260 times
- Display.jpg (44.35 KiB) Viewed 260 times
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
Re: 24-04-2021 High Cloud but Good Day
Some excellent captures there Richard and good to see your set-up too.
Thanks for sharing
Thanks for sharing
- Has thanked: 17860 times
- Been thanked: 17004 times
Very nice images Mr. Winter and I love the setup too. You are well equipped for serious work!
- Has thanked: 20828 times
- Been thanked: 10502 times
Very nice shots Richard! The sky in your picture looks like mine this morning, i'm hoping it clears up a bit. Nice to see a picture of the setup too.
- rcwinter
Hi Guys
Many thanks for your kind comments, it was a little weird as the sky looked nice just visually, however when you obscured the sun you could clearing see the high cloud albeit not obvious. I also let the tube thermals settle for close to an hour before starting as the outside temp was 16c but inside the obsy the temp was still around 8c
Please ignore the tools on the floor, took them out of my car as I had it cleaned
It took a little patience waiting for the air movement to settle enough to see that you are as close to focus as possible, it was time consuming but great that you can enjoy the warmer weather
Everyone imaging at the moment are producing fantastic stuff, and it a joy to see the skills out there, if only mine were as good.
Rich
Rich
- Has thanked: 9327 times
- Been thanked: 6163 times
Very nice images, Richard. I love the set up: is that an Astro Physics mount ?
- Been thanked: 4434 times
Very nice set of images Richard, and always enjoy seeing what people have setup for equipment too
- Been thanked: 4981 times
Richard:
A very good session through high clouds, usually difficult to focus.
- rcwinter
Hi Guys
I really enjoyed the session albeit the cloud issue, just a great day, been trying to split open Solarmax 60 Mk2 today for a focuser conversion.
Glad you liked the kit, yes it’s an AP1200, just love the mount, nothing quirky it just works, always on target, during the summer it’s my solar rig, in the Winter it does Deep Sky for me, nice and easy.
I am currently waiting to get one of the rising piers so I can get the scope a little higher, if you look at the piccy, you can see I have extended the plates however at nearly 10” long I had To try and stop vibration which I did with wooden struts and a raping band which is a ratchet type.
Does the job , polar align is spot on with ipolar. 10min subs no guiding required.
I consider myself to be very lucky getting it with no regrets on the cost, I class it as an investment
Thanks everyone
Rich
Thanks everyone
Rich
Rich,
Are you replacing the SMII 60 stock helical focuser with a Moonlite focuser?
