Good day everyone...
I had a chance to image a bit longer on Friday and was glad to have the clear skies and moderate seeing to enjoy the increased activity.
I'll start with the full disk images. The first is Ha through the LS80T/LS75FHa/B1800 with the ASI174MM camera, they are composites of separate disk and limb exposures:
The WL and CaK were images through the CR-150 OTA with an ASI1600MM camera using a Lunt Solar Wedge/Baader Continuum filter for the WL and a Lunt B1800CaK/Baader K-Line filter for the CaK image (stopped to 100mm). The WL image had limited detailed compared to the other filters (and shows me need to clean the camera):
The CaK images look much more impressive:
The balance of the images were taken with a 3x focal extender ahead of the camera for the WL and CaK images, and the pair of DSII etalons were added for the double stack Ha images...all through the CR-150 OTA.
First is AR2818:
The next image is AR2816 in Ha and CaK:
The southern hemisphere was the most interesting to me as it had a pair of long filament chains, AR2818, and a nice fila-prom on the SE limb. The image below is a 12 frame mosaic which turned out well enough, though the variable seeing does cause a bit variability across the frame:
The final image set shows the SE limb wit the fila-prom:
In all, a great day in the sun.
I also managed to set the remote pressure tuners and SSM set up Friday evening, so the next clear day should allow me to fine tune some of the operations and image capture.
April 23 in Ha/CaK/WL
- Been thanked: 4422 times
Re: April 23 in Ha/CaK/WL
An excellent set of so many captures Brian and showing so much detail and proms.
Thanks for sharing
Thanks for sharing
Terry and Peter...
Thanks for your comments and feedback...always appreciated
- Has thanked: 8543 times
- Been thanked: 8280 times
Nice images, Brian. You had a busy and productive session.
- Has thanked: 20779 times
- Been thanked: 10462 times
A very nice collection Brian!
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
Beautiful photos, I especially liked the mosaic, a variant with inversion.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
great post Brian , the hi res H-alpha is really good.
Martin
Martin
- JochenM
- Been thanked: 1619 times
Thanks for all the positive feedback on the images guys...very much appreciated
