hello everyone,
the sun around 10am UT at the fs60 with its sm40 double stack, BF10, glasspath x1.7 and zwo178mm
cordially
stephane
halpha sun on 25 April
- stef41
- Has thanked: 124 times
- Been thanked: 1490 times
- solardave
- Has thanked: 10 times
- Been thanked: 219 times
Re: halpha sun on 25 April
nice images
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Nice photos Stephane!
Thanks for sharing.
I very much like the first where the proms and a thin circle are highlighted.
Can you please explain how you achieve this? Do you take two different photos, or is it the same photo with a darker version over the light (prom) one?
All the best,
Alexandros
Thanks for sharing.
All the best,
Alexandros
Alexandros
Greece
Greece
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
Hi Stephane
Great images, lovely detail, I ask the same as Alexandros
Rich
Rich
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
- Has thanked: 8558 times
- Been thanked: 8290 times
Nice images, Stephane.
- Has thanked: 20813 times
- Been thanked: 10487 times
Very nice disks Stephane!
- stef41
thanks to you
yes, I make two films: one with just the contrasted disc (gamma 60) and the other with the saturated disc and the prominences clearly visible (gamma 25).
I then put the two resulting images together in photoshop by overlaying two layers.
for the second image, it is a single film with a gamma of 40
Sincerely
stéphane
recurring question
Sincerely
stéphane
