24 April: H alpha images at higher magnification.
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Hello Everyone.
Here are a few higher magnification images taken in H-alpha with my C8 Edge system (C8 Edge, Aries ERF, ~4.6x telecentric, Daystar 0.6A QPE, ~0.75x FR, Pt.Grey Grasshopper IMX174 cmos ). The Astrospheric app predicted a period of "excellent" seeing and actual conditions were consistent (intermittently) with the prediction but deteriorated a bit faster than forecast.
There are images of AR12816 and images of the field around AR12818 which included the very active emerging flux region S6831. Today (25Apr), S6831 has evolved into AR12820 and the entire region has become an extended active zone while AR12816 continues to decay.
Images are presented for effective focal lengths of ~ 9200mm (no FR) and ~ 7000mm (with FR). The seeing could support imaging at the shorter focal length but the high magnification results are a little soft. Typically, I stacked 25 frames out of 2000 to get reasonable sharpness (at the expense of some image noise).
Thanks for looking.
Peter
Has thanked: 9319 times
Been thanked: 6157 times
Re: 24 April: H alpha images at higher magnification.
Post by ffellah »
Brilliant images Peter: I can imagine how challenging must be to shoot at those focal lengths. What is the 4.6x telecentric you are using ?
Franco :bow
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Yes Peter, you certainly have shown some excellent images and those frames are just right too.
Thanks vm
Has thanked: 20819 times
Been thanked: 10489 times
Nice results Peter!
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Quite impressive, Peter.
Jochen Maes
Belgium
https://www.jochenmaes.com
p_zetner
Post by p_zetner »
Thank you all for the kind comments.
I've re-processed some of the images in inverted form. I actually like this view better than the direct, non-inverted images. There always seems to be the illusion of more detail.
Franco: The telecentric is a home designed / built optic. Let me know if you'd like more details.
Peter
Been thanked: 4980 times
Post by eroel »
Peter:
Beautiful results working at those long focal lengths, specially when one does not have a superb seeing.
Best wishes.
DJD
Has thanked: 42 times
Been thanked: 133 times
Post by DJD »
Great work Peter.
David
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Lovely captures Peter. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Astrophil
Been thanked: 581 times
Post by Astrophil »
A fine set of hi-res captures, Peter. Inverted images do bring out details overlooked. Nicely done.
EGRAY_OBSERVATORY
Phil has just mentioned something that is very important about inverted/negative images.
