Well why not... I can't remember when so many AR's were in such a small environment on the Sun, but late this Sunday-evening,
AR2821 has 3-spots which is the newbie on the block...
AR2820 has 12-spots
AR2818 has 1-spot (still)
AR2816 has 1-spot (very-faint)
AR2819 has 1-spot (very-faint)
Well all those close-together spots - should keep us busy for a while and hopefully..
Just look at that massive area of activity with the attached SDO images. I feel something big could occur from this region !!!
CLEAR SKIES
26-4-2021 AR2821 HAS JOINED THE MASSES
- 25-4-2021 2349z latest_512_HMII.jpg (27.59 KiB) Viewed 192 times
- 25-4-2021 2357z latest_1024_211193171.jpg (179.06 KiB) Viewed 192 times
- 26-4-2021 0008z latest_512_0304.jpg (57.89 KiB) Viewed 192 times
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: 26-4-2021 AR2821 HAS JOINED THE MASSES
Thank you Terry
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 17849 times
- Been thanked: 16992 times
AR12821 I haven't found officially listed anywhere. A magnetogram image will surely tell whether it is magnetically distinct from the other two,
You are welcome Marios and the very latest SDO image available shows the newbie 2821...
- SDO_HMIIF_512.jpg (23.41 KiB) Viewed 185 times
Well I guess James that the latest image here shows the position of AR2821 and why it is a separate AR-number from 2820 due its' close-proximity is anyone's guess, but I can only go on what the SDO retrieved image by SpaceWeatherlive.com is showing...
Got to get some kip soon.
Regards
Regards
You have found a more up to date image than the one I found. The magnetogram helps too. Visually it all looks like one big sprawled out spot complex. My observations today illustrate that.
- JochenM
- Been thanked: 1619 times
No shortage of activity on the disk right now indeed. Thanks for the heads up.
- Has thanked: 20813 times
- Been thanked: 10484 times
Thanks Terry
Thank you Jochen and Mark and yes so much to ponder over...
Regards
Regards
