Full disc capture from the 25th of April on Haleakala
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
So, I made it up to the top of Haleakala again for some more testing of seeing. Direct comparisons are hard, since you can't be 2 places at the same time, but this was try number 4, so I'm at least seeing a pattern. And I'm realizing that, at least in the daytime, the seeing in the valley between the mountains, even though at see level, seems to be better than the seeing at 10,000 feet, maybe since its after the air has been forced up the side of and across the top of the volcano? You certainly get above most of the clouds though, something that is not the case when in the backyard. I have one more spot to try to verify, but thus far the back yard seems to have the steadier/calmer/better seeing, even though there is 10k feet more atmosphere to look through. Who'd of thought, lol. I'm guessing night time, when the winds tend to be calmer everywhere, is likely a different story up there, I'll get to testing that later.
Lunt 100 with asi290mm bin1 and no reducer. Attempted using the 4x telecentric but the image was just too blurry to be of any use. There were a few glimpses of moderate seeing, but no more detail than was had in the full disc capture with no telecentric.
And a pic of the observatory on top of Haleakala, too bad they don't do public tours there, would be fun to check out!
I did get my first taste of 'public outreach' though. Being set up behind the car (using it as a wind break) drew a good amount of attention from those walking by, so I got to do my first bit of public outreach/demonstration/education, which was kind of fun! I'm normally fairly socially averse, being a bit on the spectrum, but it ended up being fun to share in person vs just online, so that was cool.
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- JochenM
- Been thanked: 1619 times
Re: Full disc capture from the 25th of April on Haleakala
Nice disk and stunning view up there!
You would indeed expect the seeing to be considerably better up there. However, I quickly looked up current weather conditions up there. A fair bit of wind (although you'll always have some on top of a mountain usually) + high jet stream is not exactly a recipe for success indeed.
If you have the opportunity to get up there when both of the above variables are in check; I'm sure you can get amazing results.
PS: very nice that you managed to do some unintended outreach
- Been thanked: 10489 times
Nice full disk and a cool place to observe! I bet it would be nice to observe CaK up there, exposure times should be a lot shorter...
- Been thanked: 2725 times
What a beautiful observing site !!
Regarding seeing, the surface layer is relatively thick because of the nature the ground. You need to get 18 m high over the ground to get excellent seeing. Unfortunatly, I can't copy/past the associated data there.
It means you need some wind to blow away the ground layer. Is there any wind up there ? It could be that the side of the top facing wind is the best. This is what we have at St Véran mountain side (2930 m).
Do you have a SSM ? It is way faster to found out where are the nice spots.
It would be great if you could share with us some picturs of the 4-m DKIST. Thanks !
BTW, very close to the sea and facing the wind, you have a laminar air flow, which is excellent for the seeing. On top of that, the difference between day/night temperatures is low, which is good for seeing.
- AJamesB
Ugh, and this is where I kick myself, lol. I have strong ADHD, and I actually went up yesterday as well for the 'ultimate' test, when jet stream was only 5km/h, but I forgot my laptop and didn't notice until I was at the top. I was gutted, lol.JochenM wrote: ↑Mon Apr 26, 2021 9:07 am Nice disk and stunning view up there!
That said, even when the the jetstream is the same speed as it was today, I get better and sharper images in the backyard than I did up top, but then again meteoblue is just all over the place. It can have all its markers be worse and yet predict better arcsecond seeing, or the opposite, all markers are green and yet it predicts poorer seeing, so who knows, lol.
I may have to invest in an SSM to really be sure. Was hoping not too, but the gas involved in getting to the top of Haleakala might end up paying for it in the end:)
asi178mm
asi294mm
asi178mm
asi294mm
- Has thanked: 9324 times
- Been thanked: 6157 times
First of all, you are very lucky to be in Hawaii. It is an amazing place. Your full disk is excellent and very evenly illuminated. It looks great ! Thank you for sharing it.
- AJamesB
When you say get 18m high, do you mean off the ground like on a platform, or just 18m high above sealevel? If the former, I don't have such a platform available to me, unfortunately. And ya, there is always a bunch of wind up there, today it averaged about 20-25mph with gusts up to 40, which from what I've read is fairly typical up there during the daytime. Backyard wind temps are much tamer, normally about 5-10mph. And trade winds typically come from the north, and the only vehichle access to the top is on the south side of the volcanic crater, so I'm stuck on the wrong side of the crater unfortunately. That's the same side as the major observatories though, so they must know something I don't. I'll keep trying:)christian viladrich wrote: ↑Mon Apr 26, 2021 10:07 am What a beautiful observing site !!
And as far as pics of the DKIST, I'll bring my zoom lens next time I'm up and try and get some close up's! Nothing was open while I was up there though, so no opportunity to peak inside. Can't get any closer either, unfortinately, especially since most of the complex is military in nature. I'll do some more reading though, there just must be a way to get in there for a tour!
asi178mm
asi294mm
asi178mm
asi294mm
- AJamesB
Thanks, ya, def lucky to be here, for that I am grateful. Disk illumination evenness is down to doing false flats in photoshop to even things out a bit. I was a little sloppy in setting up and positioning the disc, and didn't quite have everything on band and in the sweet spot of the scope. Long live post processing to save me from my lack of attention to detail.
asi178mm
asi294mm
asi178mm
asi294mm
An excellent disk James and so well on getting to the fab location.
18-Metres above ground-level = about 59-Feet is nearly twice the height of a typical two-floor house, so just about impossible for the vast majority of us, but maybe I might consider building an observatory on top of my house, if only planning-permission was feasible...
Alternatively I have a licence for operating Cherry-pickers !!!
Oh well...
Oh well...
Yes, this is indeed off the ground ;-)
Here are data from the DKIST survey at Halaekala:
- height 8 m, probability of having r0> 6 cm = 17%
- height 18 m, probability of having r0> 6 cm = 34%
- height 28 m, probability of having r0> 6 cm = 40%
- height 38 m, probability of having r0> 6 cm = 44%
Surface layer at sites near a body of water is reduced. For example Big Bear :
- height 8 m, probability of having r0> 6 cm = 50%
- height 18 m, probability of having r0> 6 cm = 57%
- height 28 m, probability of having r0> 6 cm = 60%
- height 38 m, probability of having r0> 6 cm = 62%
I would say you need two SSM :
- one running at your home site,
- one you take at the test site,
Then you can compare results at leasure.
- AJamesB
Wow, well that's good to know, interesting! Next time I change rentals I'll keep an eye out for something with roof access, or at least a really tall tree:)
And a cherry picker or service platform could work, as long as it wasn't too windy. Might get to swaying quite a bit, would make keeping the target in frame a bit of a challenge, lol.
I wonder if those that sell the SSM ever have 2 for 1 clearance sales? Never hurts to ask I guess...
asi178mm
asi294mm
asi178mm
asi294mm
- Has thanked: 17853 times
- Been thanked: 16998 times
With that altitude you need a coronagraph. You just might glimpse the solar corona, something few amateurs ever see or image outside of a total solar eclipse.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi AJames,
Great work! Truly spectacular scenery up there. I think it could get a bit scary up there !
I have been to Mount Bromo in Indonesia for milky way photography, but I think your place is even better !
How did you get such a great image ? Did you have to merge a few images or was it just a single video file and the whole sun was on the camera sensor ??
Thanks.
Magnus
Thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Loved reading this, what a place to have so close to home great full disc too. Keep us posted of your trials
- AJamesB
Thanks! Just a single video capture with the whole sun on the sensor. I'm a bit lazy and can't bring myself to do mosaics, so I do what I can (either with reducers or larger sensors) to get the full disc in a single capture. I then do histogram stretching to bring the proms into view, since they aren't visible at the exposure needed for the disc.
asi178mm
asi294mm
asi178mm
asi294mm
- AJamesB
asi178mm
asi294mm
asi178mm
asi294mm
- Been thanked: 4427 times
Great solar pic James, and the view of the observatories is a great addition
Just a question about the camera/image...is this a mosaic? I don't have full solar disk with my LS80T and without a reducer I'd think you'd have to mosaic 4 frames to cover the disk...just curious? As I said, great pic however it was done.
