Hi Guys
I have re uploaded the 26th images as they were dull and dark, hopefully these are better
You will see that comparing the images to H you can see how the AR developed over a few hours
After a late start I managed to get down to the Obsy this afternoon
The Main Ar Group was active this after were you could see it change after a few mins, I have uploaded images in sequence
As the seeing was poor I had to watch for ages to get a good spot to Capture, each image is time stamped
The images shift at one point as I took a trip round the perimeter to capture some Flares also included in the set
Hope they come over ok
Rich
26-04-2021 Busy Busy Group Today AR 2818/2820/2821
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
- 2021-04-26-1530 Sol H.jpg (437.69 KiB) Viewed 214 times
- 2021-04-26-1341_1-Sun G.jpg (464.47 KiB) Viewed 214 times
- 2021-04-26-1335_4-Sun E.jpg (449.6 KiB) Viewed 214 times
- 2021-04-26-1333_1-Sun D.jpg (443.14 KiB) Viewed 214 times
- 2021-04-26-1352_8-Sun Prom A.jpg (233.55 KiB) Viewed 279 times
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: 26-04-2021 Busy Busy Group Today AR 2818/2820/2821
Lovely captures Rich, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Indeed Richard you have well-captured the mass-action of today.
Thanks for sharing
Thanks for sharing
- Has thanked: 20773 times
- Been thanked: 10453 times
Very good Richard!
- rcwinter
HI Guys
Thanks for your kind comments, I was lucky enough to be able to capture the changes this afternoon which was nice to watch
If I had the know how and sense to do so I would have loved to capture it as an Animation, going to work on that
I was lucky that as I finished the cloud was rolling in and was just the right to call to end the day at that point
Not sure what tomorrow brings but I think it may be cloudy
Anyway thanks for all the comments I will try and lift the contrast next outing, as they looked ok after minor processing, but
then looked dull and a little darker than I thought when put up on the site I may change them tomorrow afetr work in PS
Thanks Muchly
Rich
Thanks Muchly
Rich
- Has thanked: 17829 times
- Been thanked: 16971 times
It looks like you might have caught a little flaring too!
- rcwinter
Hi Guys
Many thanks for the comments, as I suggested I have reloaded a number of images as they were dull and dark, they are much more interesting now as I lifted the contrast, you can see over the few hours I watched them how the AR developed
Lots of movement
Kind regards to you all
Rich
Lots of movement
Rich
