Sunday Sunshine With The Coronado DS90 25th April
- Been thanked: 10487 times
Back in February I bought a 90mm external double stack etalon for my SM90 scope; a couple of reasons really, I wanted a nice double stack scope to use visually and secondly I wanted something in Ha that could just be used quickly - often the the time it takes a Quark to heat up and it's cloudy again... I'd used the scope a few times but found it and my FLIR IMX174 camera just didn't get on, I just kept getting a weird Newtons rings pattern that I could never really shift... Fast forward to now and my ZWO ASI290mm camera had arrived, and was keen to try it out with a bit of mild barlow and the 290mm.
Sunday was definitely a 'grab and go' day (if you can call 11kg of scope grab and go) and continual cloud streamers seemed to sit directly over the sun for most of the morning. Time wasn't on my side either as was meeting up with friends for a couple of pints at the local at midday so any solar had to be done. With about 15 minutes to go before I was going out the sun kept poking out of the edge of the clouds for 10 or 20 seconds at a time. I managed a few shots like this, and the view was swimming on the laptop screen, but there must have been some better sub frames in the mix as I was surprised at what came out of ImPPG.
There seems to be a real synergy between this scope and camera combo, and I look forward to exploring it more when conditions are improved and time is on my side a little more... In the mean time, here are the pics...
ar12816-ha-ds90-290m-bw by Mark Townley, on Flickr
ar12816-ha-ds90-290m-colour by Mark Townley, on Flickr
ar12818-ha-ds90-290-bw by Mark Townley, on Flickr
ar12818-ha-ds90-290-colour by Mark Townley, on Flickr
ar12819-ha-ds90-290m-bw by Mark Townley, on Flickr
ar12819-ha-ds90-290m-colour by Mark Townley, on Flickr
Not the best, but not my worst! Hope you like.
Re: Sunday Sunshine With The Coronado DS90 25th April
Yes Mark - I like these a lot and the proms, surface detail and the colouring are excellent.
Thanks for sharing
Regards
Thanks for sharing
Regards
- Has thanked: 17853 times
- Been thanked: 16995 times
You have your images perfected with your SMII90! I still have some learning to do.
Very nice work Mr. Townley.
Thanks guys! I want to clock the external etalon relative to the internal one, and experience tells will yield an increase in performance. Just not got enough time to play with all these scopes that I want to
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Mark, onward and upward.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Ivan
- Has thanked: 3483 times
- Been thanked: 2263 times
Great shots, the external double stack added a lot of contrast.
We have clouds without gaps, so I find out about everything that happens in the Sun here on the forum.
- Has thanked: 8558 times
- Been thanked: 8290 times
Looking good there, Mark.
Nice contrast and evenly tuned field of view. I'm sure it will be excellent on a good seeing day.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi Mark,
Really nice images and good setup Mark.
I was wondering about the active regions. On spaceweather.com, the active regions are now numbered: AR2818, AR2820,AR2821.
1) So I am a bit confused why it is marked AR 12818. Any reason ?
2) I am no expert, but I wonder if you could get better images by limiting the number of images stacked (e.g smaller number) and dealing with noise later down the line. I have found that if you stack too many images, misalignment is more likely to occur. Technically, if you were to select the best 50-100 images manually and align them manually, you could possibly get the optimal result.
3) Have you tried ImageJ for removal of Newton Rings? I have tried it with moderate success. I am currently studying ImageJ and Fourier transforms so I can clear up my images if needed post-processing.
I have also managed to work out a mobile (2 minutes setup) with a camera tripod, Vixen Polarie and a 60mm guidescope - for visual, and I suppose imaging as well. This tracks the sun for over 30 minutes without much drift (I can get it better if polar aligned from previous night) and also if I get a geared ballhead so I can adjust the position more accurately. The imaging scope is very light and can hold the quark and camera ok.
Magnus
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Great images Mark. We are having bad weather in Portugal, no imaging during the next couple of days...
Pedro Re'
- Has thanked: 9319 times
- Been thanked: 6157 times
This scope camera combination seems to work really well for you Mark. Looking forward to seeing more results in the future.
- Davidm
- Been thanked: 289 times
Looks really good Mark. Filaproms will look fantastic with that setup.
Lunt LS152T (DSII and CaK module), Coronado Helios 1, Grasshopper 3 2/3" CCD
Thanks everyone for your kind words!
Seeing is my issue most of the time (or a lack of better seeing than I get!), you can see this in the images above on the limb, a general smoothening of the edge with lack of real spicules or jets. Lack of real detail to the proms, other than basic outline, is also a give away.
Hi Magnus. For whatever reason SW always miss of the starting '1' from the AR designation? These images are a stack of 64 frames from 4000, i've always found AS3 does an excellent job, i'm not sure I would have the patience or perseverance to select and stack manually, i'm all for automation! Noise isn't an issue, in an avi file like this noise is stochastic and will average out in stacking, generally, noise seen in presented images is a result of over sharpening or too many iterations with sharpening. I avoid flat fielding with my images, and certainly don't bother to try and remove gradients / banding in post processing, maybe im lucky, I only get it with my IMX174 in Ha.Boso36 wrote: ↑Tue Apr 27, 2021 8:25 am I was wondering about the active regions. On spaceweather.com, the active regions are now numbered: AR2818, AR2820,AR2821.
