My 26-4-2021 AR2818,2820,2821 WL CAPTURES
Well I had to wait for several-hours for a little clearing of those white fluffy things up yonder, but by around 1600z only a thin hazy-layer was to try and spoil the captures of this very-busy Regions of so many Sun-spots.
Determined to make the most of this event, I decided that the TeleVue 2•5x Powermate was the best way of capturing a close-up of all the area,
whereas the MEADE srs5000 5X TeleXtender would probably not make the best-grade from the less than favourable conditions...
Anyhow here are the three of the best with the techie-stuff in the windows
CLEAR SKIES
CLEAR SKIES
- 26-4-2021 1609z TV2.5x 200frames AR2018-2021.jpg (52.34 KiB) Viewed 251 times
- 26-4-2021 1608Z AR2818,2820,2821 Spots.jpg (97.21 KiB) Viewed 251 times
- 26-4-2021 1609z NEGATIVE TV2.5x 200frames AR2018-2021.jpg (57.8 KiB) Viewed 251 times
- Has thanked: 20962 times
- Been thanked: 10593 times
Re: My 26-4-2021 AR2818,2820,2821 WL CAPTURES
Good outcome Terry!
Thanks you Mark.
And now a modified version via imppg which is the first time I've tried that program.
Only basic-settings applied tonight, so will work on other images to see what improvements can be made...
- 26-4-2021 1609z TV2.5x 200frames AR2018-2021.jpg (52.34 KiB) Viewed 245 times
- imppg-2.jpg (75.93 KiB) Viewed 245 times
Thank you Peter and still experimenting with different methods of capture and processing too.
Cheers and Clear Skies
- Has thanked: 17960 times
- Been thanked: 17110 times
You caught these well. I didn't have time to break out the imaging equipment but I did get some decent close-up visual views of the complex. I am glad you got to image today. I need to try out IMppg.
Thank you James and yes IMppg is the first time I've tried it out, even though it's been on my system for some time and I didn't really adjust any settings on it either. Just another leaning-curve to get into my grey-cells...
Also as I'm now starting to use the various Barlows, to see which are the best for the obvious purpose - just one more learning-curve.
At least now with all the observatory mods etc., since last July, much-time is now saved in starting to get images and especially with those two large screens, one of which actually swings-out to be very-close to the scopes for very-fine adjustments (even in the bright Sun-light)...
Just need now CLEAR SKIES to allow me to experiment...
Regards
Regards
- Has thanked: 2501 times
- Been thanked: 4928 times
Well done Terry, try not to "over sharpen" in Imppg.
You can fine-tune in Photoshop if you will.
Thanks you Maurits and the imppg version was done in a hurry, as had lots of other things to do and that was my first try of that program.
I don't use PhotoShop, rather PaintShopPro which has exactly the same sharpening process and was used first before imppg, which I understand is not correct.
3-lights captured today/27th which will be processed shortly and posted too...
- Has thanked: 9387 times
- Been thanked: 6201 times
Nice captures Terry ! We all want to capture this group of sunspots, we do not get to do this very often...
- Has thanked: 8596 times
- Been thanked: 8325 times
Coming along nicely, Terry.
A suggestion, if I may? Capture more frames 2000-4000 and stack 1%, 5% and 10% (the percentages can be set prior to processing in AS!3).
Be gentle with ImPPG. Start with the default settings and work up slowly from there.
Thanks Franco and that is a super-reply.
Thanks you Stuart and yes I'm getting into this with the practice required and today's captures and processing, are (I hope) showing this practice.
I understand your comments about SharpCap downloads requiring more captures and less stacking percentage in AS, which i have started to do today,
albeit not quite with so many frames to play with today as you mention, but maybe tomorrow (weather permitting).
No rain here today - unlike much of the rest of the UK
Thanks vm
Thanks vm
