White light 26.04
GKA
Oh, I get it now!
Oh, I get it now!
Has thanked: 24 times
Been thanked: 22 times
White light 26.04
Post by GKA »
First try with my Herschel wedge , and first solar image ever.
I used a QHY5L-II-C camera , that i bought used, and it had some dirt on the sensor or glass, but i'm pleased so far.
Used a Orion 120/1000 achromat and a baader continum filter on the camera.
Late afternoon , so there was some turbulence.
Captured in Sharpcap and used Autostakkert,Registax6 and Gimp to get the finished result.
Not much compared to the other pictures in here , but i'm happy for now.Image[/img][/img]
But i need some recomendations for a mono camera and a uv/ir cut filter.
As it is now , i'm using a cheap uv/ir cut filter from svbony , but i would like one that might be better,as for the camera , would zwo 174/8 work?
Thanks.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: Whithe light 26.04
Post by EGRAY_OBSERVATORY »
That's a well sharp capture - so well done
Ylem
Has thanked: 99 times
Been thanked: 25 times
Post by Ylem »
Very nice and sharp!!!! :)
-Jeff :movie
Solar Newbie
Coronado PST,
Lot's of other astro stuff :lol:
Has thanked: 17813 times
Been thanked: 16948 times
Post by DeepSolar64 »
You did well on your first solar image. It closely resembles some of the ones I have done using my iPhone. And I have one of those Svbony UV-IR cut filters which screw into the camera nosepiece or into an eyepiece barrel. It seems to work ok, cheap or not.
Has thanked: 20738 times
Been thanked: 10437 times
Good first solar shot! I think i'd be tempted to get a green filter to use in conjunction with the setup you have already, that will give an improvement.
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Well done on your very first solar image, welcome to the bright side. People on here use either the Zwo ASI 174 or 178 mono both capable camera's. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Very nice WL image.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
marktownley wrote: Tue Apr 27, 2021 5:45 am Good first solar shot! I think i'd be tempted to get a green filter to use in conjunction with the setup you have already, that will give an improvement.
I second Mark's comment. I use a 540nm green continuum filter by Baader Planetarium. It's a nice filter and it boosts contrast well.
GKA
Oh, I get it now!
Oh, I get it now!
Post by GKA »
DeepSolar64 wrote: Wed Apr 28, 2021 5:04 am
I did, it's probably Just my editing skills, or the lack of them.
I didn't take any flats, and no stretcing in Gimp., so i will make some flats, an edit again 😊👍
By the way, how many flats should i take, i've heard evry thing from 200 to the same amount As the actual frames from solar.
Has thanked: 9292 times
Been thanked: 6128 times
Re: White light 26.04
Post by ffellah »
Well done !
GKA
Oh, I get it now!
Oh, I get it now!
Post by GKA »
Made some flats , and stacked it again , but not sure if it's any better.
But i'll keep learning.
Thanks for watching.
17_28_20 Solar 2_lapl3_ap3433 ferdig stack.jpg (165.74 KiB) Viewed 338 times
Has thanked: 17925 times
Been thanked: 8891 times
Nice WL images, you can't beat that many sunspots for a good view :bow :hamster:
