Swirling prominence and other animations from Sunday
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
I had a nice, sunny Sunday with good-to-average seeing.
Best frames, showing active regions 2018 and 2020:
Not much was happening in these ARs during this capture (30 s intervals, 1:32 h total):
My software:
My images
GreatAttractor
Re: Swirling prominence and other animations from Sunday
I started in the morning with the big prominence, it was calm enough back then (30 s intervals, 1:00 h total):
My software:
My images
GreatAttractor
...but a few hours later (I think it was the same one - it appears this way in the GONG archive) it became a bit more lively (same speed, 1:04 h total):
My software:
My images
GreatAttractor
Active regions in white light (30 s intervals, 0:34 h):
My software:
My images
GreatAttractor
A bit disappointing, I was counting on more pore movement, like in this animation from a few years back:
And finally — my first CaK animation (30 s intervals, 0:58 h total):
My software:
My images
GreatAttractor
Interesting little sparks in the lower sunspot, but according to NOAA there were no flares there at the time.
Everything captured with PGR Chameleon 3 mono (ICX445), processed with Stackistry, AviStack 2, ImPPG & GIMP.
Hα: 90/660 mm refractor + Lunt 50 etalon, Barlow 1.6x.
CaK: 90/660 mm refractor + Lunt CaK B600 module, PowerMate 2.5x.
WL: SW Mak 127, Baader Astrosolar ND 3.8 + Solar Continuum filter.
My software:
My images
Has thanked: 9296 times
Been thanked: 6131 times
Post by ffellah »
Fabulous work !
Franco :band
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Great job!
In the calcium line, everything is very dynamic.
Most of all, I liked the second animation with prominences.
Martin_S
Has thanked: 999 times
Been thanked: 3060 times
Post by Martin_S »
Amazing work, that's a great presentation.
Martin
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Great job.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 20756 times
Been thanked: 10441 times
Great set!!! You should try stopping the scope down to 60mm for the CaK, will sharpen these up considerably.
Has thanked: 17925 times
Been thanked: 8894 times
Wow!! what a delight for the senses, I think the prom animations are my favourite :bow :hamster:
GreatAttractor
Thank you, everyone.
That second prominence is the most spectacular thing I've caught in Hα so far.
My software:
My images
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Excellent prom animations, Filip.
Peter
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Excellent animations, particularly the proms.
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
The second prominence animation is awesome. Well done !!
Radon86
Has thanked: 763 times
Been thanked: 663 times
Post by Radon86 »
Lovely work Filip !
I like the large prom animation the best!
I was wondering the following (as I wish to later do some animations as well) -
What were your exposure times for the prom animation and how long/frames did you use for each one ?
How much memory would you use for 1 hours imaging ?
Do you delete the video files after processing,and if not, how long would you keep them or do you just buy more and more storage ?
Many thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
GreatAttractor
Thanks!
I have a particulary bright specimen of B600 (from my old Lunt 35; by exposure times, it was ~4x brighter than a B1200 I had borrowed for tests once), so I keep gain = 0. For the Hα surface videos the shutter time was 0.67 ms (histogram filled in about 75-80%) and 7.3 ms for the prominences (sometimes it's more for fainter ones), all at f/11.8. In all animations I was capturing for 15 s with 15 s breaks, giving 30-second animation interval. Some animations used a smaller ROI with higher framerate, so those 15 s amounted to 450-840 frames.
My camera is 1.3 Mpix (30 fps at full frame), so recording continuously would need 130 GiB/h. As mentioned above, the animations used 50% "duty cycle" and smaller ROIs, so in practice it was:
1) active region in Hα, dynamic prominence: 33 GiB/h
2) active region in CaK: 42 GiB/h
In total I recorded 240 GiB. No problem, as I have a 1 TB SSD in the acquisition laptop, of which >500 GiB is free.
After processing I keep only the raw stacks and 1-2 good videos (which are a few hundred MiB in size) of each set for future experiments. Since 2011 a 1 TB drive for all that has been sufficient.
My software:
My images
eroel
Been thanked: 4958 times
Post by eroel »
Filip:
Incredible swirling prom animation.
Beautiful work all of it.
Radon86
Post by Radon86 »
GreatAttractor wrote: Fri Apr 30, 2021 12:36 pm Thanks!
Fantastic information Filip.
Your imaging system is so much faster than the Quark. Good to know about your storage requirements are not exceeding 400 GB per day !!!
Magnus
