Prom-study ANI NNE edge (Apr. 27.2021)
- oreoluna
- Been thanked: 661 times
Hello everyone.
I processed my other protuberance recordings of the NNE edge and created the following sequence from them.
13.43h CEST ............................................... ........................13.55h CEST
14.07h CEST ............................................... .........................14.19h CEST
14.42h CEST ............................................... .........................15.05h CEST
If you take a closer look at the images, you immediately notice that the lower left part of the plasma cloud shows a certain blurring compared to the otherwise abundant structures of the protuberance.
Well why is that so?
In order to get to the bottom of the question, I created the following animation from the six individual images, although the animation is a bit bumpy, but the ANI is ideal for clarification.
Under the left part of the protuberance there is apparently an increased magnetic field activity, which has the effect that the two marked, rapidly rotating tornado protuberance: p could form below the protuberance, which is a clear indication of increased activity. The two also repeatedly show a short connection to each other via fine plasma arcs. It is therefore clear why the lower left part of the protuberance can be interpreted as "blurred"! The magnetic field extends far into the plasma cloud, and the whole "affected" area of the protuberance in the lower left part necessarily rotates with it.
LZOS 6" f8 Apo, Baader D-ERF 160, TV 4x Powermate, SolarSpectrum 0.3 À, ASI174mm.
CS,
Jozef
CS,
Jozef
- Ivan
- Has thanked: 3500 times
- Been thanked: 2285 times
Re: Prom-study ANI NNE edge (Apr. 27.2021)
That is, the" blurring " is explained by the fact that in this part of the frame, due to increased magnetic activity, the plasma movement is faster than in the rest of the frame?
- solarchat
- Site Admin
- Has thanked: 84 times
- Been thanked: 1401 times
fantastic post!
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
- oreoluna
No, the consistency of the plasma cloud is finely "atomized". But, the magnetic fields accelerate this part faster than the stable part with clear structures ..
- Been thanked: 5015 times
- Has thanked: 8588 times
- Been thanked: 8324 times
Excellent forensics, Jozef.
Great images too.
Great images too.
- Has thanked: 17941 times
- Been thanked: 17088 times
- Has thanked: 18090 times
- Been thanked: 8934 times
Fabulous!! I would also think that the lower left is moving faster than the rest so gets blurred in stacking. You can see it is rotating with the solar tornado and so has a much greater speed and the movement is horizontal.
Superb work
Superb work
- Has thanked: 20938 times
- Been thanked: 10586 times
Excellent work Jozef!
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Fantastic Jozef, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 2725 times
Excellent. I enjoyed reading this:-)
