2nd May Quiet Sun ScreenShots only
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, heads up on a quiet sun toay. Just two screenshots at the mo. a few small proms in HA and CaK. Several small filaments dotted around the disk and the small south polar filaments still present. Small plage area in the North East limb. Hopefully it might develop. Hope you're all having a lovely sunny Sunday.
- PSX_20210502_123845.jpg (449.06 KiB) Viewed 370 times
- IMG_20210502_121251__01.jpg (1.43 MiB) Viewed 370 times
- PSX_20210502_123615.jpg (518.82 KiB) Viewed 370 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: 2nd May Quiet Sun ScreenShots only
Thank you Nigella for the update and showing us some of your latest set-up.
- Has thanked: 17667 times
- Been thanked: 8789 times
Thanks for the news yes it is sunny, where did that come from as the forecast was for a miserable 2 days. I bet if get the scope out the Sun will go in, if I don't get the scope out the Sun may stay out?
- Stardust5858
Yeah, loving the new 100mm with the Lunt b1800 CaK module (pictured). I fitted a skywatcher autofocuser to it and Hitecastro usb control. Pictured with the Lunt 60mm DS.EGRAY_OBSERVATORY wrote: ↑Sun May 02, 2021 11:47 am Thank you Nigella for the update and showing us some of your latest set-up.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
It's the law of astronomy for cloud's to arrive the minute you get the equipment out
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4340 times
Nice to see the screen shots as well as the scopes Nigella...thanks for the post
- Stardust5858
Thanks Brian.MapleRidge wrote: ↑Sun May 02, 2021 2:38 pm Nice to see the screen shots as well as the scopes Nigella...thanks for the post
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Thank you for the beautiful photos. You're all so neat. Cool and compact electrofocusers, I see them for the first time.
- Has thanked: 20435 times
- Been thanked: 10245 times
Nice shots Nigella! Good to see the pics of your setup too.
- Been thanked: 4786 times
Thanks for the update Ella.
Beautiful equipment and a lovely dome.
I like the screenshots too and I see you made a "UV" preset icon.
- Stardust5858
Thanks Ivan, yes, I really find electronic focus so helpful.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Mark, I'm so behind with the processing though, at least 4/5 days worth so I thought I'd post screenshots, lol. Could be day's before I post the image's I'm afraid.marktownley wrote: ↑Sun May 02, 2021 4:52 pm Nice shots Nigella! Good to see the pics of your setup too.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Maurits, thought I'd post screenshots because I'm day's of data to work through so it could be a while before I post the results of the past several days imaging. Yes, I've found it helpful to preset UV for the calcium II K and R preset for the HA.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 16693 times
I love the setup. Observatory too!
- Stardust5858
Thanks James.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4904 times
Nigella:
Beautiful screen shots and setup.
- Has thanked: 9410 times
- Been thanked: 5568 times
Very good. I looked at the screenshot and saw in your H-alpha screenshot with Firecapture that you are clipping the white side (right of the histogram). This is not a good idea. This means you have overexposed parts. You should always have very very short flat line after the curve. Similar to what I can see in the CaK screenshot and here you can move your histogram still further to the right. Doing this gives you better details in the middle and dark tones.
I also see you use a lot of Gain. Gain always will introduce noise. I do not what the max FPS is but for example if it is 21 FPS as I see in Firecapture then the maximum exposure time could be about 45 ms and you can crank down gain. BTW, my H-alpha discs are made with an exposure time of 50 ms and I think the details are sharp.
IMHO
IMHO
- Stardust5858
Thanks Eric.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Rainer, appreciate your input. I'm new to using firecapture, usually use Sharpcap. I'll take a look at the settings next time I've got clear skies.rsfoto wrote: ↑Mon May 03, 2021 4:29 pm Hi,
IMHO
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
