Catch up 17th April 2021
- Has thanked: 17666 times
- Been thanked: 8787 times
Big catch up over the next few days. Let's start with the 17th April 2021. I can't really remember the seeing but I think it was very good.
Start off with C11 stopped to 10" / ARIES ERF / 2.5x Powermate / Lunt CaK wedge / ASI174
This was the only salvageable image
Sun_082332_17_04_2021 by Alexandra Hart, on Flickr
Immediately swapped to TEC140 stopped down to 100mm / 5x Powermate / Lunt CaK wedge / ASI174
Sun_085333_17_04_2021 by Alexandra Hart, on Flickr
Sun_085723_17_04_2021 by Alexandra Hart, on Flickr
Sun_085723_17_04_2021_f colour by Alexandra Hart, on Flickr
Sun_085935_17_04_2021 by Alexandra Hart, on Flickr
Sun_085935_17_04_2021_f colour by Alexandra Hart, on Flickr
Tried a prom but this was the best I could do
Sun_090619_17_04_2021 by Alexandra Hart, on Flickr
2021-04-17 CaK solar disc f colour by Alexandra Hart, on Flickr
Changed to Solarscope DSF100 / 1.6x Barlow / Grasshopper 3
2021-04-17 Halpha solar disc by Alexandra Hart, on Flickr
2021-04-17 Halpha solar disc f colour by Alexandra Hart, on Flickr
Click through for more detail
Then changed to 2x Barlow
Sun_101555_17_04_2021 by Alexandra Hart, on Flickr
Sun_101708_17_04_2021 by Alexandra Hart, on Flickr
Sun_101934_17_04_2021 by Alexandra Hart, on Flickr
Sun_101934_17_04_2021_invert colour by Alexandra Hart, on Flickr
Sun_101934_17_04_2021_invert by Alexandra Hart, on Flickr
Sun_102234_17_04_2021 by Alexandra Hart, on Flickr
Sun_102507_17_04_2021 by Alexandra Hart, on Flickr
Sun_102650_17_04_2021 by Alexandra Hart, on Flickr
Next instalment tomorrow will be the 24th April 2021
Thanks for surviving to the bottom of the page
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: Catch up 17th April 2021
A superb set of images, Alexandra.
- Has thanked: 9401 times
- Been thanked: 5561 times
Very good. Interesting about stopping down. Is there really a difference between 140 mm and 100 mm ?
- Been thanked: 2712 times
The Solarscope is doing very well, with top processing !
The TEC is definitely the winner when it comes to Ca K.
- Been thanked: 4904 times
Wow, what a wonderful set of images! Your Solarscope images never seem to disappoint and the inverted ones are particularly striking.
Very nice, Alexandra.
Phil
Phil
- Has thanked: 1640 times
- Been thanked: 878 times
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
That's a really good presentation Alexandra, thank you for sharing your great images.
Martin
Martin
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
An interesting and fine set of images Alexandra
Thanks for sharing
Thanks for sharing
- Has thanked: 9144 times
- Been thanked: 6025 times
You had a great session Alexandra. The results are a pleasure to see.
- Been thanked: 4786 times
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Brilliant work, Alexandra.
Your Solarscope looks excellent, high resolution noise less detailed images, fantastic !
I have a lot of catching up to do as well on my solar work.
Magnus.
Magnus.
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Has thanked: 20424 times
- Been thanked: 10243 times
Nice shots Alexandra! I agree with Christian, definitely the TEC for CaK...
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Alexandra, it takes time if you're busy to get through the backlog. I've a few days from April still to do and of course May. I need to get the April stuff done and sent off to the BAA. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
