Sun in CaK and Ha- 5th May 2021
- Has thanked: 8418 times
- Been thanked: 8163 times
A couple of FDs in Ca II K and Ha and closer view of the new magnetically disturbed region close to the eastern limb captured this morning on my front driveway. I almost didn't bother as the morning started with a covering of cloud and so I began with a few jobs in the garden. However, seeing it clearing from the west, I downed tools and set up on the drive waiting for the blue to arrive.
Ca II K (Lunt B1800/Omega filter combo)
Basler acA2440-75um
1.5x Barlow
72mm f6 Altair Astro Lightwave
20210505_CaK_FD_B1800_mono by Stuart Green, on Flickr
20210505_CaK_FD_B1800_colour by Stuart Green, on Flickr
Hydrogen Alpha (Lunt 60 mm THa/TS)
BasleracA2440-75um
1.5X Barlow
2 pane mosaic
20210505_Ha_FD_Mono by Stuart Green, on Flickr
20210505_Ha_FD_Colour by Stuart Green, on Flickr
Finally, a closer view of the disturbed region.
150mm/Lunt 35 mod
acA1920-155 um
2.5x Barlow
Processed in three flavours.....
20210505_Ha_AR_Mono by Stuart Green, on Flickr
20210505_Ha_AR_Inverted by Stuart Green, on Flickr
20210505_Ha_AR_Inverted_Colour by Stuart Green, on Flickr
Fun over... it was back to moving a tonne of slate chippings, concreting in some posts, cutting the grass......
Thanks for looking.
Basler acA2440-75um
1.5x Barlow
BasleracA2440-75um
1.5X Barlow
2 pane mosaic
150mm/Lunt 35 mod
acA1920-155 um
2.5x Barlow
Thanks for looking.
- Been thanked: 16694 times
Re: Sun in CaK and Ha- 5th May 2021
Very nice work Stu. I always enjoy your images and along with Mark T you excel at CaK imaging.
- Been thanked: 8791 times
Wow! these are absolutely fabulous Stuart, yes I agree, you have a very tight bandpass for your CaK, quite an envy
- Has thanked: 1071 times
- Been thanked: 1985 times
The edge of the HA image is just awesome. I never get the edge as well defined as that, then again im using 0.5 angstrom so i might as well wish for aliens flying past!
- Been thanked: 4787 times
Yes Stu, you have capture and produced some excellent close-ups of the fairly bland AR.
Thanks for sharing
Thanks for sharing
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Nice captures Stu, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4340 times
Superb series of images Stu...great work
- Been thanked: 10246 times
Nice results Stu! I had a go yesterday morning just after 6am, but everything was conspiring against me, need to have a look later on and see if I have anything salvageable from it
Many thanks, everyone. Hope you got your solar fix, Mark.
- Been thanked: 4904 times
Stu:
Beautiful session and results.
Clean crisp and well done.
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Good results Stu , well done.
- Has thanked: 9145 times
- Been thanked: 6025 times
