May 5th, 2021 Eruptive prominence
oreoluna
Has thanked: 1 time
Been thanked: 661 times
Post by oreoluna »
Hello everyone.
Eruptive prominence at the NE margin, rotated 90 °. On closer inspection I suspect that it was even a plasma loop!
Active region SE 16.32h CEST rotated 90 °.
8" f6 selfmade Achromat, Baader 160 D-ERF in tube, 4x TV Powermate, SolarSpectrum 0.3À, ZWO ASI290mm. :P
22Kg-Sun bucket, and Cocpit :D
CS,
Jozef
Has thanked: 9294 times
Been thanked: 6129 times
Re: May 5th, 2021 Eruptive prominence
Post by ffellah »
Great close ups, Jozef.
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Lovely captures Josef, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
oreoluna
Has thanked: 1 time
Post by oreoluna »
Hello Franco, Stardust.
Thanks for your kind feedback.
Jozef
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Great solar image Jozef, and nice to see your scope as well :bow
Has thanked: 17813 times
Been thanked: 16950 times
Post by DeepSolar64 »
I noticed this prom on the GONG image that I was using for reference today but when I looked in the place the GONG ( Big Bear Ca ) showed the prom all I saw there visually was a much smaller dimmer prom. It had already came and went by the time the image was updated. I was just a little too late to see it visually.
Thanks for an excellent view of it Jozef. And that is a really nice homebuilt solar refractor. I dream of an instrument 6" or over for solar work AND the seeing to utilize it!
And an eruptive prominence often signals an active area's presence!
Has thanked: 20738 times
Been thanked: 10439 times
Super shots Josef, nice to see a picture of the setup too, looks an ideal place to do solar from.
oreoluna
Has thanked: 1 time
Post by oreoluna »
Hello everyone.
Thank you for your kind feedback.
@James.
The weather yesterday was a catastrophe, stormy westerly winds and thick clouds. I had to solve a problem with the cam transmission to the PC, so the weather was fine. I also changed the telescope on the occasion to see what my old self-made 8-inch model can reproduce with the SolarSpectrum. It wasn't after 4 p.m. that there was a gap every now and then and I immediately thought of testing the station wagon. If the seeing was very bad, due to the wind and the additional load on the telescope, I was able to take the pictures ..... I'm excited to see what will come about when the conditions are better.
I caught the "loop" by chance in a gap in the cloud. The spicules are just smeared pulp, and show how the seeing was!
CS,
Jozef
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Great close-ups Jozef and beautiful equipment.
Jozef, how can you know (measure) de diameter of the Earth in function of the sunspot or active region?
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
oreoluna
Has thanked: 1 time
Post by oreoluna »
MAURITS wrote: Thu May 06, 2021 7:16 am Great close-ups Jozef and beautiful equipment.
Hello Maurits.
Thanks for the feedback.
I do not measure, but I know that my magnification factor for the sun is such that the earth in the picture must be 40x40 pixels. And the easiest way is: Spicule height 7-8`000Km Earth 12714Km diameter. So you can + - balance the earth well on the spicules. On the chromosphere it is the rosettes, which have an average diameter of 12-15,000 km. That is then also simply the earth + - to be compared there.
CS Jozef
oreoluna
Has thanked: 1 time
Post by oreoluna »
DeepSolar64 wrote: Thu May 06, 2021 4:32 am And an eruptive prominence often signals an active area's presence!
Hello James.
Yes, that is always or often the case. Today I looked at the area on the Northeast edge in the GONG Monitor,
and I think there is definitely an active region coming. ;)
Jozef
Valtori
Has thanked: 312 times
Been thanked: 182 times
Post by Valtori »
Very beautiful shots and setup!!
Val
Rusted
Has thanked: 8114 times
Been thanked: 1941 times
Post by Rusted »
Great images and a fascinating instrument. :bow
The scale of the surface features is impressive!
Plus, a short, but pleasant walk to the observatory. :D
That's an excellent set-up Jozef!
Has thanked: 17925 times
Been thanked: 8891 times
Wow!! these are phenomenal, amazing if you say the seeing was bad :bow :bow
Sadly Solarspectrum no longer make your model :(
Montana wrote: Thu May 06, 2021 5:14 pm Sadly Solarspectrum no longer make your model :(
What do they make?
oreoluna
Has thanked: 1 time
Post by oreoluna »
Oh dear, did I buy the last one? :P
CS Jozef
None at all at the moment as far as I can gather Mark :(
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Interesting and excellent images and set-up Jozef
Thanks for sharing
Been thanked: 4957 times
Post by eroel »
Jozef, super images and super setup.
Still remember when you started building the solar refractor.
Best regards.
