7-5-2021 AR282(2) LARGE AR IN THE N.E. LIMB AREA
The attached SDO images clearly shows a large (very large) AR is now visible as has just emerged over the North-Eastern limb, as expected.
This is a very active region and has flared - whilst still on the dark-side..
Already at least apparent Sun-spots are visible in the hi-res image.
- 7-5-2021 1059z latest_512_HMII.jpg (27.04 KiB) Viewed 208 times
- Been thanked: 4981 times
Re: 7-5-2021 AR282(2) LARGE AR IN THE N.E. LIMB AREA
Terry, thanks for the info, will try to image today.
Many thanks Eric.
Will be good to see your captures, as I have just in the last hour tried to get a capture, but alas, they grey-stuff has rolled overhead and the satellite-imagery looks as if it is unlikely to get another look today.
Much of the same stuff expected over this weekend too..
Regards
Regards
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Thanks Terry, managed a full session today and saw the new AR/spots.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Yes Nigella, your excellent screen-shots earlier - also showed well this new AR and its' spots.
Hopefully of course, we could be in for something big after that sleepy break...
- Been thanked: 8907 times
Excellent news! just saw this on Nigella's pics I think Jozef picked it up with the eruptive proms yesterday
Hi Alexandra, yes I think you are correct about Jozef picking-up those proms and it is being reported elsewhere as such activity.
Nigella certainly has shown the almost identical images that SDO showed earlier and I must admit that she caught me by surprise earlier today, as I had a very late night-time session and failed to wake-up till nearly mid-day, so I have to blame Nigella, for getting the latest captures - in first...
I did try eventually this afternoon in getting the observatory ready for some WL imaging of the newbie, but as usual the grey (this time) stuff just blocked any possibility and noting a different direction of high cloud layer on the satellite imagery, decided that today is a no go...
- Has thanked: 17856 times
- Been thanked: 17003 times
I've got the new AR in the NE. 4 spots. One fully structured!
Thanks James and yes so many spots and still flaring as well.
Might even be a CME on the way from this very-active region...
Now numbered (at last) as AR2822 is showing as 5-spots at datum and the latest SDO image shows how active this AR is...
- 7-5-2021 2207z latest_512_0193.jpg (42.94 KiB) Viewed 148 times
- Been thanked: 4434 times
Thanks for the update Terry!
I'm hoping for some sun over the weekend.
