7th May FD CaK, HA and WL
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, well it's taken me all evening to process these from today 7th May 2021. As headed up before there's a lovely new AR and spot region on the North Eastern limb. Still loads of data to go through these past several days but I think these will just be sent off to the British Astronomical Associations Solar Section. Take care everyone.
- 20210705-080209UTellabryant-FDWL-col.jpg (1.13 MiB) Viewed 480 times
- 20210705-080209UTellabryant-FDWL.jpg (1.1 MiB) Viewed 480 times
- 20210705-074613UTellabryant-ARHA-invert-col.jpg (702.25 KiB) Viewed 480 times
- 20210705-074613UTellabryant-ARHA-invert.jpg (402.85 KiB) Viewed 480 times
- 20210705-074613UTellabryant-ARHA-col.jpg (805.56 KiB) Viewed 480 times
- 20210705-074613UTellabryant-ARHA.jpg (314.51 KiB) Viewed 480 times
- 20210705-090234UTellabryant-FDHA-proms-col.jpg (896.13 KiB) Viewed 480 times
- 20210705-090234UTellabryant-FDHA-proms.jpg (1.14 MiB) Viewed 480 times
- 20210705-074921UTellabryant-FDHA-col.jpg (1014.54 KiB) Viewed 480 times
- 20210705-074921UTellabryant-FDHA.jpg (914.63 KiB) Viewed 480 times
- 20210705-073036UTellabryant-ARCaK-invert-col.jpg (722.3 KiB) Viewed 480 times
- 20210705-073036UTellabryant-ARCaK-invert.jpg (452.32 KiB) Viewed 480 times
- 20210705-073036UTellabryant-ARCaK-col.jpg (539.12 KiB) Viewed 480 times
- 20210705-073036UTellabryant-ARCaK.jpg (324.03 KiB) Viewed 480 times
- 20210705-072703UTellabryant-FDCakproms-col.jpg (832.78 KiB) Viewed 480 times
- 20210705-072703UTellabryant-FDCakproms.jpg (626.95 KiB) Viewed 480 times
- 20210705-072524UTellabryant-FDCaK-invertcol.jpg (1.08 MiB) Viewed 480 times
- 20210705-072524UTellabryant-FDCaK-invert.jpg (1.07 MiB) Viewed 480 times
- 20210705-072524UTellabryant-FDCaK-col.jpg (940.25 KiB) Viewed 480 times
- 20210705-072524UTellabryant-FDCaK.jpg (851.59 KiB) Viewed 480 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: 7th May FD CaK, HA and WL
You've certainly captured the newbie very well indeed Nigella and even some activity rising with in it too..
Excellent captures and thanks vm for sharing
- Stardust5858
Thanks Terry, appreciate your comment. Yes, I noticed the activity rising in the new AR too. I hope we're not clouded out for days as it seems a nice active region.EGRAY_OBSERVATORY wrote: ↑Fri May 07, 2021 11:18 pm You've certainly captured the newbie very well indeed Nigella and even some activity rising with in it too..
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4406 times
Beautiful images Nigella
- Has thanked: 17807 times
- Been thanked: 16942 times
Very nice work Nigella! Beautifully done!!
- Stardust5858
Thanks Brian, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks James, much appreciated. I think I could have done a little better with the processing. Didn't go through all the data capture's so there could be better, certainly some worse, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 2462 times
- Been thanked: 4878 times
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Wow Nigella you really caught this AR at just the right time, there are some great images, well done.
Martin
Martin
- Has thanked: 17894 times
- Been thanked: 8887 times
Wow!! that is one special collection of images, beautifully done I love your CaK proms, I tried again recently and I see absolutely nothing at all of any proms with my module, you are very lucky!
- Stardust5858
Thanks Maurits, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Alexandra, appreciate your comments. Don't know why my CaK module show's the proms but has done from the first time I used it. I was rather taken aback as I thought you couldn't see proms in CaK, at least it would be difficult, but seems not with my module. Someone said I'd got a near perfect wavelength module, who knows. I guess they are hit and miss like all commercial solar equipment. I guess you've tried upping the gamma, gain, I know I'm speaking to an expert with many years experience so apologise if you have.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
You do have a remarkable unit, never sell it!
I have tried boosting absolutely everything until the black sky is white, nothing but a faint ghost if I am lucky
- Stardust5858
Oh dear, that's a pity. Yeah, I've been told never to sell it already by the person who said it's an almost perfect wavelength. So definitely not, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi Nigella,Stardust5858 wrote: ↑Fri May 07, 2021 9:51 pm Hi all, well it's taken me all evening to process these from today 7th May 2021. As headed up before there's a lovely new AR and spot region on the North Eastern limb. Still loads of data to go through these past several days but I think these will just be sent off to the British Astronomical Associations Solar Section. Take care everyone.
Fantastic work, lovely images Nigella !
"... Hi all, well it's taken me all evening...."" ?, well I think it would take me a few days, maybe weeks ? to process at the moment.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Stardust5858
Thanks Magnus, much appreciatedBoso36 wrote: ↑Sun May 09, 2021 6:38 amHi Nigella,Stardust5858 wrote: ↑Fri May 07, 2021 9:51 pm Hi all, well it's taken me all evening to process these from today 7th May 2021. As headed up before there's a lovely new AR and spot region on the North Eastern limb. Still loads of data to go through these past several days but I think these will just be sent off to the British Astronomical Associations Solar Section. Take care everyone.
Magnus
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20738 times
- Been thanked: 10431 times
Nice images Nigella!
- pedro
- Has thanked: 14 times
- Been thanked: 6683 times
fantastic images Nigella, well done
Pedro Re'
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Really great images, Nigella, CaK prominences came out particularly well, a very beautiful sight!
Raf
- Stardust5858
Thanks very much Pedro, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Raf, much appreciated.krakatoa1883 wrote: ↑Sun May 09, 2021 1:11 pm Really great images, Nigella, CaK prominences came out particularly well, a very beautiful sight!
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Mark, much appreciated. Clouded out here for the weekend, Tuesday looks promising so hopefully get another chance at a session.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
