Session time is 10:00am until 10:38am EDT local time ( US ). The skies are partly cloudy. Seeing is good. The temperature is 61F.
Coronado SolarMax II 60 DS. 16x, 21.5x, 33x, 50x and 66.5x ( Ha )
I can see two plages on the solar disc. The newly numbered AR12822 in the NE is bright and easy to see. Within the plage I can see three spots. I can also see another plage in the SE approaching the LCM. It shows an east-west bipolar form and has thin filaments located south and west of it. I can also see a filament in the far SE and another in the SW near the limb. I also see a couple of filaments in the NE.
I can see a bright prom in the SW and another in the SE that is largely un-attached to the disc. The lifted off part is housetop shaped. I also see a small one on the NW limb and a tall " sprite " on the NE limb.
The mottles show nice contrast today and at higher powers ( 50x and 66.5x ) I can see the limb spicule layer.
Orion 70mm Solar Telescope. 25x, 41.5x, 50x 62.5x and 100x ( WL )
I can see 6 spots/pores in AR12822 in the NE. The faculae is easy to see also. The large northernmost spot shows an elongated umbra within a well formed penumbra. I tried for polar faculae but could not see them. The C102 with the wedge would probably win out here! I can see the fine granulation of the photosphere but here a wedge equipped scope would show them better. Though the filter does decent a solar wedge exceeds it in contrast and detail and that makes a difference on stuff like faculae and granulation. It makes them easier to see!
I see no other spots/pores on the disc.
Carpe Diem!
May 8 2021 Observations
- Has thanked: 17914 times
- Been thanked: 17056 times
- Has thanked: 18048 times
- Been thanked: 8913 times
Re: May 8 2021 Observations
An interesting Sun it sounds James thanks for the walk around nothing but rain all day today here.
- MAURITS
- Has thanked: 2496 times
- Been thanked: 4917 times
- Been thanked: 4900 times
Yes that's right about the more visible as time goes on and also unable to see from here either...
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Thanks James for your report. Much appreciated. I'm clouded out here too
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20902 times
- Been thanked: 10558 times
Thanks for the report James, hoping I can catch this pot in the early mornings this week before work.
Thanks guys, I'll be your eyes when you're cloudy if you will be mine when I am cloudy.
