May 8 2021 Observations
Has thanked: 17807 times
Been thanked: 16944 times
Post by DeepSolar64 »
Session time is 10:00am until 10:38am EDT local time ( US ). The skies are partly cloudy. Seeing is good. The temperature is 61F.
Coronado SolarMax II 60 DS. 16x, 21.5x, 33x, 50x and 66.5x ( Ha )
I can see two plages on the solar disc. The newly numbered AR12822 in the NE is bright and easy to see. Within the plage I can see three spots. I can also see another plage in the SE approaching the LCM. It shows an east-west bipolar form and has thin filaments located south and west of it. I can also see a filament in the far SE and another in the SW near the limb. I also see a couple of filaments in the NE.
I can see a bright prom in the SW and another in the SE that is largely un-attached to the disc. The lifted off part is housetop shaped. I also see a small one on the NW limb and a tall " sprite " on the NE limb.
The mottles show nice contrast today and at higher powers ( 50x and 66.5x ) I can see the limb spicule layer.
Orion 70mm Solar Telescope. 25x, 41.5x, 50x 62.5x and 100x ( WL )
I can see 6 spots/pores in AR12822 in the NE. The faculae is easy to see also. The large northernmost spot shows an elongated umbra within a well formed penumbra. I tried for polar faculae but could not see them. The C102 with the wedge would probably win out here! I can see the fine granulation of the photosphere but here a wedge equipped scope would show them better. Though the filter does decent a solar wedge exceeds it in contrast and detail and that makes a difference on stuff like faculae and granulation. It makes them easier to see!
I see no other spots/pores on the disc.
Carpe Diem!
Has thanked: 17901 times
Been thanked: 8888 times
Re: May 8 2021 Observations
An interesting Sun it sounds James :hamster: thanks for the walk around :) nothing but rain all day today here.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Every day a bit more visible James, thanks for sharing.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Yes that's right about the more visible as time goes on and also unable to see from here either...
Thanks
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Thanks James for your report. Much appreciated. I'm clouded out here too 😭
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Has thanked: 20738 times
Been thanked: 10435 times
Thanks for the report James, hoping I can catch this pot in the early mornings this week before work.
Thanks guys, I'll be your eyes when you're cloudy if you will be mine when I am cloudy. ;)
