Heya,
Happy mother's day to all, hope you have a wonderful weekend or memory of your loved ones!
I was able to get a little sky time this morning, a quick 20ish minute session. Seeing was fairly good this morning with a much smaller temperature delta as my summer weather is rolling in after a weird cold snap in early May here in Florida. AR2822 presented in photosphere and the upper & lower chromosphere at the same image scales.
B&W:
Colored:
Seeing:
Equipment:
120mm F10 (masked) achromatic doublet refractor
2" Baader Blue CCD IR Block Filter (internal sub-aperture D-ERF) -> Lunt CaK B1200 -> ASI290MM (CaK)
2" Baader Red CCD IR Block Filter (internal sub-aperture D-ERF) -> Baader ND3.0 Filter -> ASI290MM (WL)
2" Baader Red CCD IR Block Filter (internal sub-aperture D-ERF) -> HA filter + 1.7A x 2 BF Stack -> ASI290MM (HA)
AR2822 (WL, HA, CaK) | May 9th 2021
- Has thanked: 1188 times
- Been thanked: 1382 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: AR2822 (WL, HA, CaK) | May 9th 2021
Great to see the development of the Active region. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20779 times
- Been thanked: 10462 times
A good set of images there Marty, glad to see you getting some sun, hoping I manage to get some these early mornings before work this week...
- Has thanked: 17970 times
- Been thanked: 8905 times
These are gorgeous Marty, especially the CaK shots I'm glad you got a little sunshine, we have had the most miserable weekend weatherwise.
