May, 09 2021 - Sun in three wavelenghts & AR12822
- Has thanked: 214 times
- Been thanked: 146 times
Hello,
A bit of sunshine without strong gusts of wind, at least!
Pleasant imaging session, seeing and transparency were "normal".
Starting with Ca-k:
cak__2021-05-09_T2 by Fabio Immovilli, su Flickr
Time to move closer in WL:
wl__2021-05-09_T2 by Fabio Immovilli, su Flickr
Finally, switching over to Ha: I need to adjust my tilting adapter, since some NR sometimes appear.
ha__2021-05-09_T_1U by Fabio Immovilli, su Flickr
ha__2021-05-09_T_2U by Fabio Immovilli, su Flickr
ha__2021-05-09_T_3U by Fabio Immovilli, su Flickr
Fabio
Technical data:
Ca-k setup:
C80ED + Lunt Ca-k module 1800
WL photographic setup:
C80ED + 2" UV/IR cut + 2" Baader solar continuum (on 80mm extension tubes) + ND3 filter & 5x barlow on camera nose
H-alpha setup
C80ED + Daystar Quark Chromosphere
Camera:
Basler acA1920-155um
Software:
Genika + Autostakkert + Registax 6
Starting with Ca-k:
Fabio
Technical data:
Ca-k setup:
H-alpha setup
Camera:
Software:
Flickr album https://www.flickr.com/photos/190949744@N08/
- Has thanked: 18105 times
- Been thanked: 8942 times
Re: May, 09 2021 - Sun in three wavelenghts & AR12822
Very nice images indeed it looks like a new AR in the SE that you spotted
- Has thanked: 2501 times
- Been thanked: 4928 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Fabio, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9387 times
- Been thanked: 6201 times
Very good images Fabio ! Some of the best images today are coming from Italy...
- Ivan
- Has thanked: 3500 times
- Been thanked: 2285 times
The pictures in WL and the calcium lines complement each other so wonderfully.
- Has thanked: 8596 times
- Been thanked: 8325 times
Good images, Fabio. Nicely done.
Thank you Fabio for sharing some excellent captures and of the new AR in the S.E. Quadrant, which will appear shortly on SolarChat.
- Has thanked: 17960 times
- Been thanked: 17110 times
The Ha and WL images show far more visually than I could see today. I could only see 6 spots in the AR. You resolved spots into spots!
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Nice images, Fabio.
Raf
Thank you all for your kind comments
Clear skies
Fabio
Clear skies
Fabio
- Has thanked: 20962 times
- Been thanked: 10593 times
A very nice set of images FAbio!
- Been thanked: 5016 times
Fabio:
Beautiful clean images, well done.
