May 9 2021 - Extreme Close up and HA shot
- Has thanked: 1075 times
- Been thanked: 1986 times
So seeing was fluttering from good to excellent so i decided to try my luck and go extreme. The white light images are shot using an Esprit 150 with a 2x and a 5x powermate. I am at the edge of maxing out the scopes useful magnification as focus was virtually impossible. Suddenly, a clear moment happened and I got what is probably the closest image of convection cells i have ever managed!
The Sunspot wasnt as good but when they are near the limb, they never are. Fingers crossed in about 3 days when I have a excellent seeing forecast, I will try again!
This is a quick look at AR12822
I have tons and tons of data to go through still!
Re: May 9 2021 - Extreme Close up and HA shot
Superb images Simon and definitely the best to date of the current action over the last two days.
That porridge-image shows such detail, as does the AR2822 captures as well.
Just shows what a little bit of decent seeing can do, as well as your available set-up's...
Thanks for sharing
Thanks for sharing
I still have to go thru 400gb of data to find the clearest shots. I was so excited to see the convection cells that everything because secondary!
EGRAY_OBSERVATORY wrote: ↑Sun May 09, 2021 5:36 pm Superb images Simon and definitely the best to date of the current action over the last two days.
Thanks for sharing
- Has thanked: 17970 times
- Been thanked: 8905 times
Wow!! absolutely cracking!! I am a real WL granulation fan
Beautiful!!! I prefer the positive images though
Oddly enough, so do I. The reason why I invert white light is to get a better look at the spots themselves. The convection cells when inverted always look super weird.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Stunning captures, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Brilliant work SImon!!!Simon2940 wrote: ↑Sun May 09, 2021 5:26 pm So seeing was fluttering from good to excellent so i decided to try my luck and go extreme. The white light images are shot using an Esprit 150 with a 2x and a 5x powermate. I am at the edge of maxing out the scopes useful magnification as focus was virtually impossible. Suddenly, a clear moment happened and I got what is probably the closest image of convection cells i have ever managed!
I would be really keen to maybe follow up on the sun spot, over the next 14 days and image every day, or twice a day, to see how that evolves with time. The weather/seeing conditions may not allow that though.
I think its time for you to buy another hard drive/SSD drive ??
Good luck !
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Has thanked: 9307 times
- Been thanked: 6144 times
Beautiful results Simon ! If I may ask, where are you located ?
Los Angeles, Ca - 30 miles north of it to be exact in a place called Santa Clarita.
- Has thanked: 8543 times
- Been thanked: 8280 times
Excellent images, Simon. Lots of great detail in these.
- Has thanked: 17845 times
- Been thanked: 16977 times
WoW!!, absolutely stunning. All are awesome but the first one with the Esprit 150 is incredible. It looks like a pro image. I dream of imaging the granulation in such detail or actually seeing it! I would have guessed an 8" or bigger scope for this. Five thumbs up from me!
- Has thanked: 20779 times
- Been thanked: 10462 times
These really are excellent Simon!
