Heads Up 10th May
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Heads Up 10th May
Hi all, heads up on new spot, active area, South Eastern quarter. Screenshot's only at the mo. Have a great day. Update, added two more screenshots in WL one showing the two spots in the new AR.
- Screenshot (18).png (1.32 MiB) Viewed 365 times
- Screenshot (17).png (778.52 KiB) Viewed 365 times
- Screenshot (15).png (587.41 KiB) Viewed 383 times
- Screenshot (14).png (851.39 KiB) Viewed 383 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: Heads Up 10th May
Your screen shots are a welcome-change Nigella and still show the relevant detail too, as well as the FC settings.
I must remember to look them up - when eventually I get round to trying-out FC.
The newbie AR is now confirmed as AR2823 consisting of two-spots at datum.
AR2822 is now showing up to seven-spots at datum.
You've certainly captured all the spot-action, so well done and thanks vm for sharing
- Stardust5858
Thanks Terry, I was surprised to see the new spot group this morning. I did see two spots in the new group.EGRAY_OBSERVATORY wrote: ↑Mon May 10, 2021 11:21 am Your screen shots are a welcome-change Nigella and still show the relevant detail too, as well as the FC settings.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 2501 times
- Been thanked: 4928 times
It's nice to see the relationship between the FC settings and the images.
Thanks for sharing with us Ella.
- Ivan
- Has thanked: 3500 times
- Been thanked: 2285 times
- Stardust5858
Thanks Maurits, yeah it is, although I've only used screenshots for convenience of posting on the heads up instead of waiting on processing the data, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Ivan, hopefully it might help others too
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 18105 times
- Been thanked: 8942 times
You say " Thanks Ivan, hopefully it might help others too " - that is very true Nigella and very useful for two newer Solar image'rs, which I have been helping and certainly with FC will also help me trial that soon...
Well done and thank you that lady, now all you is need a secretary to do your processing... b b
- Been thanked: 5016 times
Nigella:
It sure helps to see the camera parameters, I still remember many many years ago that most well known astroimagers kept their parameters as top secret.
That was very hard for the new imagers at that time, we had to experiment a lot to get results.
Fortunately that has changed.
Best wishes.
Best wishes.
- Stardust5858
Thanks Terry, yes, that's a great idea, I need an assistant to do the processing, after all, most observatories have a post grad assistant, lol.EGRAY_OBSERVATORY wrote: ↑Mon May 10, 2021 2:52 pm You say " Thanks Ivan, hopefully it might help others too " - that is very true Nigella and very useful for two newer Solar image'rs, which I have been helping and certainly with FC will also help me trial that soon...
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
I don't see the point in keeping settings secret, why would someone. I have found on the planetary imaging side of things that kind of thing. Trying to get help is hard, especially RGB.eroel wrote: ↑Mon May 10, 2021 3:41 pm Nigella:
Best wishes.
Helping one another should be second nature and I love this forum for just that.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Hear hear!!! that is exactly what this forum is about Nigella, no secrets
We all should be able to get great images, I don't keep anything secret, what is the point, the Sun is here for us all to freely see
- Stardust5858
Thanks Alexandra, hope you get the chance to see the sun this weekend.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
And why not, lol. Have a great time.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
That's always the challenge.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20962 times
- Been thanked: 10593 times
Thanks Nigella, hoping I get some sun in the early morning slots this week.
- Stardust5858
Hope you do Mark, clear skies for us all, lol.marktownley wrote: ↑Mon May 10, 2021 7:10 pm Thanks Nigella, hoping I get some sun in the early morning slots this week.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
