May 10 2021 Observations
- Has thanked: 17845 times
- Been thanked: 16979 times
Session time is 10:58am until 12.02pm EDT local time ( US ). The skies are mostly cloudy. The seeing is decent. The temperature is 72F. I am back home in Edneyville NC today.
Coronado SolarMax II 90 DS. 32x, 64x, 100x and 133x ( Ha )
I can see two easy plages today. AR12822 in the NE shows spots amid a tattered plage. No sign of flare activity. I can see a couple of thin filaments associated with it. Well to it's south I see another active region plage that has an easy spot in it's SE region. Well to the west of the SE plage I see what is now just a mere disturbance but it's large in size, the decaying remains of a plage.
I can see a smattering of filaments in the south and a couple in the north but nothing of any real significance.
The prominences look good. I can see as many in single stack as the GONG images show, One in the SW looks good and shows fine detail. It looks somewhat like a misshapen horses head looking north. It even has a sideways oriented eye. A void or bubble within it. There is also a lot of filamentary details within it. The spicule layer on the limb looked nice too and the individual spicules could be seen, especially the taller macro-spicules. 100x did wonderfully. I tried 133x but it was a bit much for the seeing conditions.
The mottles were of good contrast and easily seen covering the solar disc.
Celestron NexStar 102GT w/Altair wedge and Baader 540nm filter. 55x and 100x ( WL )
I can see 13 spots/pores in AR12822. The two largest spots have incomplete penumbrae oriented in the same direction. SDO images show this easily too. While I do get a good view the 4K SDO imagery still out resolves me a bit.
The second active region in the SE shows 7 spots/pores to my telescopic eye. The large one shows some penumbra and a large elongated umbra. A tiny pore is close by and takes moments of good seeing to see. To the northwest is a cluster of pores. Only one of these may be considered a small spot. SDO HMI imagery here out resolves me a bit revealing just a little bit more than I can see.
I see no faculae on the disc at all. Granulation is visible.
All while listening to Ryan Farish, Spectrum.
Carpe Lumen!
Hopefully I can get back to imaging soon.
Carpe Lumen!
- Been thanked: 8905 times
Re: May 10 2021 Observations
I am sure we would have had a lot to talk about. Do you like Riesling?
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely report James. Thanks again. Was able to have a full session this morning too. Nice to see another spot group/active region.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20783 times
- Been thanked: 10468 times
Solar and music, lots of fun James!
James has got the correct combination of the right music and Solar viewing/imaging, which even with me having a back-breaking and painful day finishing-off the final wiring for the Uninterruptable Power Supply in the observatory, crawling around at very low-levels, but the classical-music certainly dampened-down my not so nice-language at times !!
(I bet I won't have a power-failure again compared to twice this year. So just got to install the house-generator as well next)...
Well done James for your efforts in providing the valuable updates.
Thanks
Thanks
- Been thanked: 4971 times
James, a nice report and music.
I usually hear classic music when imaging.
Best regards.
Best regards.
Mark, Terry and Eric,
Music always enlightens the mood for solar observing. With me it is usually classical, soft Jazz or new age music. I rarely drink alcohol during observing sessions. It's usually coffee since solar generally takes place in the morning or early afternoon.
That's natural music! I do sometimes leave the stereo off and listen to the birds as well.
So far today is not looking good. Cloudy.
- Has thanked: 8544 times
- Been thanked: 8282 times
Thanks for your report, James. Sounds idyllic.
You are welcome Stuart. I'm hoping for a session on the 12th but it doesn't look good with the weather.
