Hi All
Today was the second short session with 130/7 Lunt80 SS mod. Let's say, AR12822 closeup and prom on SW limb came out quite Ok with 174mm+TZ-4. Tried to proceed with DS, but seeing has deteriorated quickly.
regards
Leo
May 10 AR12822
- Has thanked: 1277 times
- Been thanked: 1070 times
May 10 AR12822
- SW prom
- Sun_20210510 105022_cEAI.jpg (524.84 KiB) Viewed 231 times
- AR
- Sun_20210510 112418_AIdPs3.jpg (928.58 KiB) Viewed 231 times
Re: May 10 AR12822
Hello Leo, you have certainly done an exceedingly good job with those two captures.
thanks vm for sharing
- Has thanked: 17849 times
- Been thanked: 16992 times
Re: May 10 AR12822
Leo,
Both turned out really well with a lot of detail.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: May 10 AR12822
Stunning captures, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9319 times
- Been thanked: 6157 times
- Has thanked: 20813 times
- Been thanked: 10484 times
Re: May 10 AR12822
Nice captures Leo!
Re: May 10 AR12822
Thanks to all, very appreciated!
Mark, you were interested in the TS APO 130/7 Lunt80MT mod details. Well, in fact, I made the simplest adapter between the frac and etalons with the Lunt stock focuser as it is. At first sight, the sweet spot is about to cover FD with SS and all proms are visible around the limb, but I didn't investigate it well yet in DS mode. I use the setup with full aperture Baader D-ERF 135 keeping a red glass filter before the front etalon. I'll make further comparison with my Quark Chromo, but it's clear there are advantages of uniform FOV, no vignetting issues scaling down with focal reducers etc. I understand there is no free lunch in such cases, but at the moment it looks promising to use Lunt rear DS system.
Hope this helps.
Clear skies
Leo
Hope this helps.
Clear skies
Leo
- PSX_20210512_000848.jpg (287.77 KiB) Viewed 164 times
- PSX_20210511_224919.jpg (120.65 KiB) Viewed 164 times
