11th May AM - WL CAPTURES
Well at last, some very clear-skies which woke me-up earlier than usual, but knowing the thick grey stuff was on the horizon, at least I captured in all three-lights. Ha and CaK will follow in due course...
The first set here, are just single-frames using also the TeleVue 2.5X PowerMate for the individual Sun-spots in White-Light using the Lunt 1.25" Hershel Wedge. Seeing was turbulent, so no doubt the stacked versions should be better.
Better processing is in the offing, but lots to get through and the stacked captures will appear as soon as on the post...
Enjoy and thanks for looking
- 2021-05-11 0924z AR2822.jpg (109.98 KiB) Viewed 260 times
- 11-5-2021 0927z WL AR2823 X200PC.jpg (73.26 KiB) Viewed 260 times
- 11-5-2021 0920z WL AR2822, AR2823.jpg (151.83 KiB) Viewed 260 times
- Has thanked: 17667 times
- Been thanked: 8789 times
Re: 11th May AM - WL CAPTURES
Nice work Terry, glad to see you finally getting some Sun hours rather than crawling about with all the cables
Ha Ha Alexandra, yes it was not the nicest of chores, but all done now and everything working fine out there. Thanks you
- Been thanked: 16693 times
That last almost full disc one looks really good, Terry.
- Been thanked: 4904 times
Terry:
The last image is very clean and crisp, beautiful shot.
Many thanks for the useful comments James and Eric.
I am still learning and practicing to get better, with still lots of processing to do to try and catch-up with the fab images on SolarChat.
Regards
terry
Regards
terry
- Been thanked: 4786 times
The last result is beautiful Terry.
Always difficult using new equipment.
Thanks again Maurits, even though the Ha and Cak scopes are ten years old, but kept in a humidity controlled environment and the Orion ED80T-CF does have an issue of Dust inside the objective and being of Carbon-Fibre, the lens cannot be removed, so I developed a vacuum system to try and extract the debris, but even that hasn't worked.
Also there are other problems in the manufacturing-design of the ED-80, which I have rectified, but sooner or later I will change to a similar Vixen type or the William Optics Fluorostar 91 APO Triplet etc., which can serve for both Solar-WL and night sky purposes.
Cheers for now
Cheers for now
- Has thanked: 8415 times
- Been thanked: 8161 times
Nice almost full disk, Terry.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Great you got a session too Terry, at least you've posted them. My assistant refused to do all my processing and decided to go mousing instead, lol.
- IMG_20210507_082058__01.jpg (1.64 MiB) Viewed 207 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
WOW that cat scared me as I had the screen magnifier on and was about to reply to Stu when suddenly the Moggie ran-up my screen. I hope it hasn't scratched it...!!!
So how much will hubby charge to help out then Nigella ?? *!*!*!*!*!
Stu, I think the last time I did some WL-ing I had a 0.5FR in the rig, but I know I've now got three of those in the filter-case, so checking out the website, I'll see if I can get a 0.7 or 0.8FR so to get the FD. I might also look at using my other Barlows too...
The less glass in the way the better - I would have thought..
Thanks and cheers
Thanks and cheers
- Has thanked: 20435 times
- Been thanked: 10245 times
Good shots Terry! That last one came out the best.
