It's certainly been a fruitful day today for a short session with ultra-blue skies, but even though a little turbulent, SharpCap and AutoStakkert have done the business.
More to come - after grub-up...
I hope you enjoy and thanks for looking.
MORE CAPTURES of 5th May'21 in Ha
- 11-5-2021 0905z Ha-SS.jpg (795.7 KiB) Viewed 222 times
- 11-5-2021 0908z Ha-Proms.jpg (564.77 KiB) Viewed 222 times
- 11-5-2021 0908z Ha-proms-100fr.jpg (289.16 KiB) Viewed 222 times
- 11-5-2021 0908z Ha-promsA-100fr.jpg (44.57 KiB) Viewed 222 times
- 11-5-2021 0908z Ha-promsB-100fr.jpg (21.94 KiB) Viewed 222 times
- 11-5-2021 0908z Ha-promsC-100fr.jpg (22.55 KiB) Viewed 222 times
- 11-5-2021 0908z Ha-promsD-100fr.jpg (22.27 KiB) Viewed 222 times
- Has thanked: 2501 times
- Been thanked: 4924 times
Re: MORE CAPTURES of 5th May'21 in Ha
Terry, nice and colorful collection.
I'am a big fan too from SharpCap, used @ 90% of the time.
Thank you again Maurits.
I think one of the benefits of SC is the simplicity of get a good or even better result from some other progs.
Also I just love the fact that I can have the three Tri-scope cameras all plugged into a 4-way USB-3 port next to the scopes and then a USB-3 3-metre cable to the Professional Computer (not a laptop), which itself has absolutely every possible type of socket from RS-232 to HDMI-out and four
USB-3 and four USB-2 ports etc etc. What more can I ask for, albeit I do have a small-business supplier nearby - who knew exactly what I required and came-up with the goods... It's also very fast on the internet, even through a 100'/30+Metre Ethernet extension to the observatory... !!!
Also being a computer without a battery, he has supplied a mint-condition UPS (Uninterruptable Power Supply) primarily to back-up the computer in the event of, but also supplies emergency lighting etc etc..
With SharpCap, and in its' Camera tab, all the cameras show-up and I just have to tap for which camera to use - without all the messing around of changing cameras around and plugs etc....
All the Best
Back to more processing...
Regards
All the Best
Regards
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
That is the beauty of Sharpcap as against firecapture but I've been using firecapture of late but love the fact that I can plug all three scopes in like yourself. Thanks for sharing your images Terry, well done.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Thank you Nigella and I am trying to catch you up with your excellent quality images, but at least our CaK scopes are the best...
Ok on the three cam/SC use and i can even leave the PoleMaster camera in to the system too, as SC is excellent for using that prog.
All the Best.
All the Best.
- Has thanked: 20938 times
- Been thanked: 10586 times
Nice Ha shots Terry!
Thank you Mark and just seen the heading date of the 5th, I made another mistook !!!
- Has thanked: 18090 times
- Been thanked: 8934 times
Wow!! what a prom!!
I presume you mean 11th May in the title ?
- Has thanked: 9379 times
- Been thanked: 6198 times
Thanks to Alexandra, Franco and StarHugger - whom I imagine replied via FaceBook (or similar). Sorry, I don't/Won't use those type of web-sites, as insecure etc..
