Full Disk Mosaic in Ha with AR12822 and AR12823
- minhlead
- Has thanked: 738 times
- Been thanked: 1104 times
I try to do a mosaic with my 107 scope and the result is underwhelming. Maybe bad seeing is contributing to some local lost of contrast.
15 panels, 100 best of 500 frames each.Minh.
Loves from Viet Nam <3
My gear:
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
My gear:
Camera:
Re: Full Disk Mosaic in Ha with AR12822 and AR12823
That's a beautiful image under the "seeing conditions" Minh.
Thanks for sharing
Thanks for sharing
- Been thanked: 8791 times
That's a great attempt doing a mosaic is a tough job especially with 15 panels, you did very well. It takes a lot of luck to get a seamless image with consistency between panels and the greater the number the chances get harder.
- minhlead
Thanks Alexandra. It's really hell of a job aligning and blending the mosaic.
I've never thought bad seeing even under high transparentcy can affects things that much. I'll be better prepared next time.EGRAY_OBSERVATORY wrote: ↑Wed May 12, 2021 10:44 am That's a beautiful image under the "seeing conditions" Minh.
Thanks for sharing
Minh.
My gear:
Camera:
My gear:
Camera:
Indeed Minh, just a matter of patience for the best weather and more practice too..
Best Wishes
terry
Best Wishes
terry
- Been thanked: 10246 times
Good result in the circumstances, Quarks aren't designed for this, you're also off band (in the red). Try stopping the 107 down.
- minhlead
Yeah, the Quark going off band due to the extreme ambient heat that day (about 40 degree celsius). Could you please share how did you know that?marktownley wrote: ↑Wed May 12, 2021 7:04 pm Good result in the circumstances, Quarks aren't designed for this, you're also off band (in the red). Try stopping the 107 down.
Minh.
My gear:
Camera:
My gear:
Camera:
- Been thanked: 16694 times
minhlead wrote: ↑Thu May 13, 2021 12:05 amYeah, the Quark going off band due to the extreme ambient heat that day (about 40 degree celsius). Could you please share how did you know that?marktownley wrote: ↑Wed May 12, 2021 7:04 pm Good result in the circumstances, Quarks aren't designed for this, you're also off band (in the red). Try stopping the 107 down.
I wondered that too. Mark has good eyes and lots of experience. Still, how can he tell that. It's not obvious to my inexperienced eyes.
If you look closely you will see dark rosettes of mottles across the disc, they are flat and dark with white patches between. If on band the mottles would be 3D in structure and fluffy with no obvious white patches around, the surface would be more uniform and stuck up like grass. Very hard to describe but if you look at Rainers images you see this bumpy effect of mottles rather than dark rosettes viewtopic.php?f=4&t=31709
I hope this helps
I hope this helps
- minhlead
Thanks Alexandra. I kinda see it now. But I still have a question, how did Mark know I was in the red ?Montana wrote: ↑Thu May 13, 2021 8:06 am If you look closely you will see dark rosettes of mottles across the disc, they are flat and dark with white patches between. If on band the mottles would be 3D in structure and fluffy with no obvious white patches around, the surface would be more uniform and stuck up like grass. Very hard to describe but if you look at Rainers images you see this bumpy effect of mottles rather than dark rosettes viewtopic.php?f=4&t=31709
I hope this helps
Minh.
My gear:
Camera:
My gear:
Camera:
Well, there is a simple answer to that but you have to look very closely. According to Zirin (Astrophysics of the Sun) p 174 in the blue wing the spicules are doubles called 'twinning'. In the red wing the spicules are singles. That is the only way I know that you can tell. I need to scan in the photo for you don't I
- minhlead
Montana wrote: ↑Thu May 13, 2021 2:09 pm Well, there is a simple answer to that but you have to look very closely. According to Zirin (Astrophysics of the Sun) p 174 in the blue wing the spicules are doubles called 'twinning'. In the red wing the spicules are singles. That is the only way I know that you can tell. I need to scan in the photo for you don't I
I am speechless
Minh.
My gear:
Camera:
My gear:
Camera:
- Has thanked: 9413 times
- Been thanked: 5578 times
That is an excellent result for using 15 panels. The H-alpha also from my point of view is in Band. Maybe put a bit more attention in focusing ?
IMHO
IMHO
- minhlead
Since the seeing was so bad I can't chase the focus and settle on what "looks" the best. Will try again with better seeing later. Thanka
Minh.
My gear:
Camera:
My gear:
Camera:
For exactly the reason Alexandra has just described!minhlead wrote: ↑Thu May 13, 2021 11:06 amThanks Alexandra. I kinda see it now. But I still have a question, how did Mark know I was in the red ?Montana wrote: ↑Thu May 13, 2021 8:06 am If you look closely you will see dark rosettes of mottles across the disc, they are flat and dark with white patches between. If on band the mottles would be 3D in structure and fluffy with no obvious white patches around, the surface would be more uniform and stuck up like grass. Very hard to describe but if you look at Rainers images you see this bumpy effect of mottles rather than dark rosettes viewtopic.php?f=4&t=31709
I hope this helps
