Heads Up 12th May
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Heads Up 12th May
Hi all, heads up on new plage area, Eastern limb. Screenshots for info in HA and CaK. Hope you all have a nice day.
- Screenshot (30).png (998.21 KiB) Viewed 197 times
- Screenshot (25).png (402.55 KiB) Viewed 197 times
- Screenshot (29).png (946.61 KiB) Viewed 197 times
- Screenshot (35).png (841.58 KiB) Viewed 197 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: Heads Up 12th May
Yes Nigella you've just captured the newbie, which I am about to report here.
Thanks for the excellent SS images of FC.
Have a good day
Have a good day
- Stardust5858
Thanks Terry, just managed a session before the weather turns. I was up early, lol. At least the sun is active again.EGRAY_OBSERVATORY wrote: ↑Wed May 12, 2021 10:48 am Yes Nigella you've just captured the newbie, which I am about to report here.
Have a good day
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17667 times
- Been thanked: 8787 times
You do show some excellent images at capture, I can just see the newbie region on the CaK
Of course Nigella, the earlier getting images the better, when the sky is usually less turbulent too.
Unfortunately for me the earliest is usually around midday, but when the blue sky allows will try earlier, as happened yesterday.
Best Wishes
Best Wishes
- Has thanked: 20424 times
- Been thanked: 10243 times
Looking good!
- Stardust5858
Thanks everyone, I just do it for convenience and quickness to give an indication of what's up. I find it really hard to get the time to process the same day/week. Not sure if I caught a flare again today, definitely caught one yesterday. Still to process.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
I must admit that I've been up all night in the observatory using the computer rather than any imaging, but I could stay-up to get some early Sun-burn whilst imaging it, but alas I have to do the necessaries and pay for a new scope to be imported as soon as possible for early June, so a few hours kip and then back to the grind...
I have PM'd yourself Nigella
Thanks
Thanks
