May 13 2021 Imaging.
- Has thanked: 17849 times
- Been thanked: 16992 times
Everyone,
Here is the images from today's observing session. I hope you like them.
Though they turned out Ok I could see detail beyond them, especially in white light.
Re: May 13 2021 Imaging.
Nice to see James, beautiful coloring too.
These are fantastic James
I presume the Halpha are single stack? the proms are superb
- Has thanked: 9319 times
- Been thanked: 6157 times
The second one is in double stack. I always seem to image proms better than I do the disc. I don't know why. I did miss seeing large filaments on the disc.
Excellent captures from you James.
You are doing very well with the 178 and your set-up, so thanks vm for sharing
Regards
Regards
Thanks Terry,
I should have mentioned my set-up. The Ha images were taken with my Coronado SMII90 and the 540nm photosphere image with my Celestron 102mm F10 refractor using the ZWO ASI178MM monochrome camera.
Thank you James and a neat setup especially with the "Stacking Bin" over the pc - also neat and very effective and relatively cheap to do the same job as some others sold...
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely James, well done. I especially like the prom one's. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20813 times
- Been thanked: 10485 times
Very nice James!
Thanks for the compliments and input everyone. And Terry that stacking bin works like a charm!
