05.14.21 Sun in Lunt50
- Ivan
- Has thanked: 3483 times
- Been thanked: 2263 times
Hello everyone.
Today it is cloudy and windy, the visibility is good, sometimes terrible. I wanted to make an animation, but half of the stacks went to the basket, maybe I'll still try to put together a short video.
In the meantime, the sun is in Ha 14.05.21.
I am learning ImPPG, and experimenting with color and processing. I'm new to filming too, so I'd love to hear your tips and tricks.
30% of 1000 frames would have stacked less, but the quality of the entire video was very good, even rare for me.
Lunt50
x2 Barlow Lens
qhy img0s
Ivan
Lunt50
x2 Barlow Lens
qhy img0s
Ivan
- 14.05.21 color.jpg (649.75 KiB) Viewed 503 times
- 14.05.21 mono inv.jpg (436.44 KiB) Viewed 503 times
- 14.05.21 mono.jpg (435.39 KiB) Viewed 503 times
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
Re: 05.14.21 Sun in Lunt50
Lovely captures. No technical problems left, I see.
Just one suggestion, for the second style of post-processing, I personally would manipulate the tone curve so that the background goes to black outside the limb.
- Has thanked: 17853 times
- Been thanked: 16996 times
Ivan, Nicely done. The AR plages stand out well. I never could get them to " pop " like this.
- Ivan
Thanks for your comments.
Filip, thanks for your recommendation, that's what I wanted to do at first. But if I made the background dark, then small protrusions on the limb disappeared, as in the color version.
I am just studying your magic program, Alexandra recommended it to me. I think I will learn over time.
Maurits, James thanks for the kind words.
Ivan
Ivan
Other than the red-coloured capture being a tad too-bright on both my screens (one slightly dimmer), these are excellent images, showing a lot of detail.
Thanks Ivan for sharing
- Ivan
Peter, thanks.
Terry, I couldn't have done it without your help. I was just desperate, but thanks to you, everything worked out.EGRAY_OBSERVATORY wrote: ↑Fri May 14, 2021 11:02 pm Other than the red-coloured capture being a tad too-bright on both my screens (one slightly dimmer), these are excellent images, showing a lot of detail.
Ivan
- Been thanked: 10489 times
Very nice!
- GreatAttractor
It should be doable; if you'd like to post the raw stack, I can give it a try and provide an ImPPG settings file.
- Ivan
Thanks a lot FilipGreatAttractor wrote: ↑Sat May 15, 2021 6:50 pmIt should be doable; if you'd like to post the raw stack, I can give it a try and provide an ImPPG settings file.
I posted it here: https://flic.kr/p/2kZ8BNX
Its size is 1.57 Mb. It would be great to see your processing option.
Ivan
- Been thanked: 4980 times
- GreatAttractor
- Ivan
Thanks Filip.
It turned out very nicely. I see the settings file. I will try to persuade.
Ivan
