14th May Solar Session in HA and CaK
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, posting solar imaging session from yesterday 14th May using a Lunt 60mm DS and 100mm AR. Zwo asi 178mm camera was used in all captures. Seeing was quite bad with atmospheric undulations across the field of view.
- 20210514-151455UTellabryant-FDCaK-closeup-col.jpg (694.41 KiB) Viewed 158 times
- 20210514-151455UTellabryant-FDCaK-closeup.jpg (646.67 KiB) Viewed 158 times
- 20210514-151455UTellabryant-FDCaK-col.jpg (972.5 KiB) Viewed 158 times
- 20210514-151455UTellabryant-FDCaK.jpg (755.2 KiB) Viewed 158 times
- 20210514-151004UTellabryant-FDHA-proms-col.jpg (1017.77 KiB) Viewed 158 times
- 20210514-150828UTellabryant-FDHA-invert-col.jpg (919.25 KiB) Viewed 158 times
- 20210514-150828UTellabryant-FDHA-invert.jpg (1008.79 KiB) Viewed 158 times
- 20210514-150828UTellabryant-FDHA.jpg (864.51 KiB) Viewed 158 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Re: 14th May Solar Session in HA and CaK
Thanks very much, appreciated.StarHugger wrote: ↑Sat May 15, 2021 6:43 pm These are very nice captures Nigella thanks, clouds today but did get ok seeing yesterday and maybe tomorrow. Best of luck all.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Hi Ella,
You are catching up very-well with the latest collection of excellent images and colouring too.
Thanks vm for sharing
- Been thanked: 10489 times
Nice shots Ella, no such luck for me with the weather at the moment...
