15th May very short session.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, a very short session between very fast morning clouds. The dome was being buffeted by gusts of wind and the seeing wasn't that great. I only managed to capture one decent image in Calciam II K, it was impossible to use the HA. I did spot another small spot development in the plage East of AR2822 nearer the North Eastern Limb and what seems like a new plage area on the South Eastern limb coming onto the disk. 100mm AR stopped down to 80mm, zwo asi 178mm Camera.
- 20210515-151236UTellabryant-FDCaK-col.jpg (923.93 KiB) Viewed 231 times
- 20210515-151236UTellabryant-FDCaK-eb.jpg (903.51 KiB) Viewed 231 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: 15th May very short session.
Thank you Ella for an excellent report of your seeing and the fab images too.
Maybe some more action over the side as a small AR is about to emerge with another larger one too. Let's hope so and glad you had some clear-skies today, compared to here.
- euvi_195_heliographic.jpg (46.31 KiB) Viewed 209 times
- Stardust5858
Thanks Terry, it was challenging but glad I persisted. Yes, let's hope for more active regions around the corner. Sorry you weren't able to see anything. Hopefully our weather will improve. We live in hope, lol.EGRAY_OBSERVATORY wrote: ↑Sat May 15, 2021 10:50 pm Thank you Ella for an excellent report of your seeing and the fab images too.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20783 times
- Been thanked: 10464 times
Nice disk Ella! Try sharpening at a smaller radius and you will tease finer details out of the image.
- Been thanked: 4422 times
Great shots Ella
- Has thanked: 17845 times
- Been thanked: 16977 times
As I already know a short session is better than no session. Fine job Ella!
- Stardust5858
Many thanks Mark, will try that.marktownley wrote: ↑Sun May 16, 2021 6:21 am Nice disk Ella! Try sharpening at a smaller radius and you will tease finer details out of the image.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
That is very true James.DeepSolar64 wrote: ↑Sun May 16, 2021 11:09 pm As I already know a short session is better than no session. Fine job Ella!
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
