Flare in Calcium II K 12th May
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Posting some images from the 12th. I think I caught a C1.5 flare in calcium II K. Of course I might be wrong but there is definitely a brightening within AR 2822 on the images taken at 09:37UT and 09:47UT the same time as the noted flare beginning at 09:15UT and ending 09:47UT
- 12th may2021 flare.jpg (228.25 KiB) Viewed 628 times
- 20210512-1014UTellabryant-FDCaK-closeup.jpg (772.7 KiB) Viewed 628 times
- 20210512-1014UTellabryant-FDCaK.jpg (862.86 KiB) Viewed 628 times
- 20210512-1014UTellabryant-FDCaK-closeup-col.jpg (855.78 KiB) Viewed 628 times
- 20210512-1014UTellabryant-FDCaK-col.jpg (1.08 MiB) Viewed 628 times
- 20210512-0947UTellabryant-FDCaK-flare-closeup.jpg (612.45 KiB) Viewed 628 times
- 20210512-0947UTellabryant-FDCaK-flare.jpg (817.31 KiB) Viewed 628 times
- 20210512-0947UTellabryant-FDCaK-flare-col-closeup.jpg (850.6 KiB) Viewed 628 times
- 20210512-0947UTellabryant-FDCaK-flare-col.jpg (1.04 MiB) Viewed 628 times
- 20210512-0937UTellabryant-FDCaK-flarecloseup.jpg (719.27 KiB) Viewed 628 times
- 20210512-0937UTellabryant-FDCaK-flare.jpg (1.03 MiB) Viewed 628 times
- 20210512-0937UTellabryant-FDCaK-flarecloseup-COL.jpg (960.45 KiB) Viewed 628 times
- 20210512-0937UTellabryant-FDCaK-flare-col.jpg (822.19 KiB) Viewed 628 times
- 20210512-090620UTellabryant-ARCaK.jpg (986.55 KiB) Viewed 628 times
- 20210512-090620UTellabryant-ARCaK-col.jpg (748.94 KiB) Viewed 628 times
- 20210512-070324UTellabryant-FDCaK-closeup.jpg (641.81 KiB) Viewed 628 times
- 20210512-070324UTellabryant-FDCaK.jpg (1.11 MiB) Viewed 628 times
- 20210512-070324UTellabryant-CaK-preflare-closeup.jpg (882.67 KiB) Viewed 628 times
- 20210512-070324UTellabryant-FDCaK-col.jpg (966.31 KiB) Viewed 628 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17853 times
- Been thanked: 16996 times
Re: Flare in Calcium II K 12th May
It looks like you caught it!
- Stardust5858
It does doesn't it James.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Certainly does look so Ella, so very well captured and an excellent presentation too
Thanks for sharing
Thanks for sharing
- Stardust5858
Many thanks Terry, yeah, quite excited about capturing it in CaK.EGRAY_OBSERVATORY wrote: ↑Sat May 15, 2021 10:55 pm Certainly does look so Ella, so very well captured and an excellent presentation too
Thanks for sharing
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 10489 times
You got a good set here Ella, flares are easy to spot in CaK. What software are you using to sharpen?
- JochenM
- Been thanked: 1619 times
- Stardust5858
Thanks Mark. I just use ImPPG to sharpen.marktownley wrote: ↑Sun May 16, 2021 6:29 am You got a good set here Ella, flares are easy to spot in CaK. What software are you using to sharpen?
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Jochen, appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Beautiful presentation and very nice and clean Cak images Ella, I like the FD's a lot.
- Stardust5858
Thanks Maurits, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 2725 times
Yes you have it ! Well done.
Clear skies
Christian
Clear skies
Christian
- Stardust5858
Thanks Peter, your comments are very appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Christian, your comment is very much appreciated. My very first flare in Calcium II K, lol.christian viladrich wrote: ↑Sun May 16, 2021 1:03 pm Yes you have it ! Well done.
Clear skies
Christian
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4980 times
Nigella:
Beautiful session and yes, you got the flare in CaK.
Best regards.
Best regards.
- Stardust5858
Thanks Eric, I did, didn't I, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fine images, Nigella, congratulations. I always prefer the non-colorized CaK, but it's a matter of personal taste, of course.
Raf
- Stardust5858
Thanks Raf, that's why I post both mono and false colour, catering for both tastes, lol.krakatoa1883 wrote: ↑Sun May 16, 2021 6:24 pm Fine images, Nigella, congratulations. I always prefer the non-colorized CaK, but it's a matter of personal taste, of course.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4427 times
Great series of CaK images Ella...well done
- Stardust5858
Thanks Brian, appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 6305 times
- Been thanked: 7324 times
- Stardust5858
Thanks Arne, much appreciated.arnedanielsen wrote: ↑Mon May 17, 2021 11:05 am Great run Ella. Thanks for sharing!
Arne
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
