AR2822 May 15, 2021
- Has thanked: 9145 times
- Been thanked: 6026 times
AR2822 May 15, 2021
Hello all: this morning good seeing with the jetstream finally south of us. I still have to process a lot of data but this is a first experiment with the HaT fitted with the 0.7 focal reducer, the Solar Spectrum filter and a newly acquired PG 9.1 Mp CCD camera. It is a mid field, pardon the basic processing but I think the set produced interesting results.
Hope you like it.
Hope you like it.
- 084643 AR2822.jpg (1.86 MiB) Viewed 454 times
- 084643 AR2822 inverted.jpg (1.37 MiB) Viewed 454 times
- 084643 AR2822 mono.jpg (1.45 MiB) Viewed 454 times
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: AR2822 May 15, 2021
Very nice work Franco. Your setup worked very well. Your disc images easily surpass mine today. What size HaT do you have? The C8 Edge model?
That jet stream must have moved south over me. My seeing was considerably worse today compared to yesterday and Thursday.
- Has thanked: 8418 times
- Been thanked: 8165 times
That’s a heck of a nice setup, Franco. Nice images too. Just cloud and showers here.
- Been thanked: 10248 times
Nice results Franco! I have the same camera. Is it the edge HD 0.7 reducer you're using?
- JochenM
- Been thanked: 1619 times
- Been thanked: 4787 times
Thank you James, Stu, Mark, Jochen, Maurits and Peter for your kind words. James: this is not a competition. I look at this as a form of personal expression, all images presented are great and they reflect some of the personal interests of the member that presents them. We all learn from each other and this is what this forum is all about, at least for me.
Mark: yes, that is the reducer.
I have been working on this three image mosaic of a AR2822 close up. This was done with the HaT and a Quark Combo at f/27.5: the seeing was good but borderline for high res.
- 093809 ImPPG_stitch final mono.jpg (2.05 MiB) Viewed 394 times
- 093809 ImPPG_stitch final mono inverted.jpg (2.02 MiB) Viewed 394 times
Exceptionally well-done Franco for your fab-work.
An interesting and good reply to James about learning from others.
Thanks vm for sharing
- Been thanked: 4904 times
Thank you James, Stu, Mark, Jochen, Maurits and Peter for your kind words. James: this is not a competition. I look at this as a form of personal expression, all images presented are great and they reflect some of the personal interests of the member that presents them. We all learn from each other and this is what this forum is all about, at least for me._Franco
Franco,
I agree with you fully here. It's not a competition but it is certainly a great opportunity to learn so when I see someone with similar looking images as mine but are a bit different, sharper, better contrast etc I wonder " How did he/she do it? What scope or equipment did they use. What processing trick? I am a newbie to imaging so I have always got questions
Personal expression it is but I use imaging more as a way of documentation backing what I see visually. Or at least that is the idea.
And we all have fun doing it!!
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
great images, Franco, very crisp.
Raf
Thank you Terry, Eric, James and Raf, greatly appreciated. James: you may consider yourself a newbie but your images show the enormous progress you have made in a very short time. The rest is detail that you pick up here and there in the forum, tips about processing, equipment and combinations of hardware that work well together. Sometime it takes years, depending on how much time you put into it. I think you are doing fantastic.
- Been thanked: 4340 times
Superb results from the new setup Franco...excellent capture and processing
Thank you Franco. I would have never caught on as fast as I have if it wasn't for members here. It seems proms are my strength at the moment.ffellah wrote: ↑Sun May 16, 2021 7:09 pm Thank you Terry, Eric, James and Raf, greatly appreciated. James: you may consider yourself a newbie but your images show the enormous progress you have made in a very short time. The rest is detail that you pick up here and there in the forum, tips about processing, equipment and combinations of hardware that work well together. Sometime it takes years, depending on how much time you put into it. I think you are doing fantastic.
Beautiful images, Franco. That sounds like a very capable setup you put together. Glad to see the solar spectrum back in action.
Phil
Phil
Thanks a lot Brian and Phil. The Solar Spectrum finally came home after one and a half year !
