May 12th - Ha Light
- Been thanked: 4340 times
May 12th - Ha Light
Good day everyone...
I snuck a short session in on the 12th over lunch, but swamped at work and just finished processing the images tonight. I was glad to get more images of the new AR's and was surprised to see the large proms on the southern limb too. I was limited for time so I only ran the Ha set of filters.
First image is the full disk through the LS80T/LS75FHa/B1800Ha solar scope and ASI174MM camera: I setup the modded CR-150 OTA and double stacked DSII etalons with the B1800Ha for higher resolution images of the more active regions. The ASI290MM camera was used for these images: The first image is AR2822 and another small active spot to its south-west: To the south of this large AR was AR2823: There was some new activity starting to appear in the NE as well: The final image was the disturbed region in the south that was starting to rotate off the disk: The seeing was getting very poor by the time I was through the disk series of images and the best attempts at the proms were a lost cause! Thanks what I get for starting at 1pm.
I hope everyone enjoys these! Questions and comments are always welcome.
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: May 12th - Ha Light
Those look really good. Nice detail is shown in those active regions. I love the bright orange color as well!
- viewer
- Has thanked: 233 times
- Been thanked: 23 times
Excellent! Nice prominence catch, they really show off on the southern limb. Will try to sketch the more modest proms of today . Time tables, not to talk about weather, partly rule our lives. Nice you got this in!
Eq-2 mount on the balcony, pst, mak with baader filter, zoom, camera asi290mm
Sketches and images: https://www.cloudynights.com/gallery/me ... 07-viewer/
- Has thanked: 8418 times
- Been thanked: 8165 times
A fine set of images, Brian. Nicely done.
- Been thanked: 10248 times
These came out really well given the conditions Brian, glad you got some sunshine in!
- JochenM
- Been thanked: 1619 times
Good to see you managed to sneak a quick session in, Brian. Nice results as always.
- Been thanked: 4787 times
Thanks for all of the comments and feedback to all who replied...always very much appreciated
If the clouds thin out I hope to get some more images between the chores list at home today
- Has thanked: 9145 times
- Been thanked: 6027 times
These came out really well Brian. I love that large prom at the bottom, you caught it perfectly. I also like very much the orange coloring of the Ha disk.
A beautiful set of images Brian.
The colouring is perfect too.
Thanks vm for sharing
- Been thanked: 4904 times
Brian:
A beautiful clean and crisp images.
Liked them all.
Best regards.
Liked them all.
Best regards.
Franco, Terry, and Eric...
Thanks for your comments on the session...always appreciated
