Session time is noon to noon-thirty EDT local time ( US ). The skies are mostly cloudy. The seeing is fair. The temperature is 72F. Today's observations were quick views through holes in the clouds. I had no time to look for fine details.
Coronado SolarMax II 60 DS. 16x, 21.5x and 33x ( Ha )
I can see five plage areas on the solar disc today! AR12822 is in the northwest with another small plage to it's immediate west. AR12823 is in the southeast. The southeast has two plages. A larger faint one and a second smaller one near the limb.
I can see dark filaments in the southeast and southwest near the limb. I also see a thin curved filament in the southeast below the small plage and above the larger dark filament. I can see three prominences on the solar limb. GONG CT shows more proms and a filament in the northeast plus some associated with AR12822. I did not notice these at a glance and clouds did not allow me a closer look.
The mottles were visible.
I can see only a single spot in AR12822 but surprisingly it has re-structured itself! No light bridges! It is now well formed and structurally symmetrical. It shows both umbra and penumbra. I cannot see it's faculae but I do see another facula west of it.
The only other faculae I can see on the Sun is in the southeast. I see no spots within it.
The fine solar granulation is visible covering the disc today.
Carpe Lumen!
May 16 2021 Observations
- Has thanked: 17860 times
- Been thanked: 17006 times
- Been thanked: 4881 times
- Been thanked: 4434 times
Re: May 16 2021 Observations
Good report James!
The Ha views today were great, and I hope the images turn out too
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Thanks for your report James, always interesting, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Thanks James and the SDO images another quiet-ish spell with AR2822.
Thanks vm
Thanks vm
Brian, I did not image today but I did yesterday. Check out that post!MapleRidge wrote: ↑Sun May 16, 2021 8:33 pm Good report James!
Terry,
The NE limb is showing signs of activity on the SDO images.
- Has thanked: 20828 times
- Been thanked: 10502 times
Thanks James, the cloud persists here...
You are welcome Mark. I hope you clear.
