I didn't expect much today from a sky covered with wispy streamers but the seeing was actually better than usual. Unfortunately, the stacking was difficult because the wispy clouds crossing the sun were interpreted as solar features
and produced a mess in most cases. Two exceptions allowed capture of 2 of the larger prom features.
The first image was taken with a 180mm Mak with a 1.5X telecentric producing a f/22 beam (efl = 4050mm) for a Quark Combo Chromosphere.
https://www.deviantart.com/giovannigabr ... -879830830
The second image was taken with a 180mm Mak with a 2X Powermate producing a f/30 beam (efl = 5400mm) for a Quark Combo Chromosphere.
https://www.deviantart.com/giovannigabr ... -879830552
My problem with disabled gamma om my Grasshopper(2.3Mp) was solved, helped by P. Zetner's suggestion about setting the video mode to 7. I also had to uncheck "Advanced mode" at the top of the video mode page. Also, for some reason, the camera defaults to RAW format when started up. This had to be manually changed to Mono before the gamma control was allowed. I have to find out whether the default settings can be altered.
I've yet to find out why Firecapture disables the gamma control with either my Blackfly S or my Grasshopper.
I use Firecapture 2.7beta with Spinnaker for the Blackfly S and Firecapture 2.6 with the latest Flycapture for the Grasshopper.
Lou
Nice proms on May 17
- Been thanked: 1735 times
- Has thanked: 1640 times
- Been thanked: 878 times
Re: Nice proms on May 17
Those turned out nice! How do you prevent tube currents on the mak? Insulation?
- Has thanked: 20435 times
- Been thanked: 10245 times
Good results Lou!
- Been thanked: 4786 times
- Has thanked: 8418 times
- Been thanked: 8162 times
Looking great, Lou. Nice proms.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Lou, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9145 times
- Been thanked: 6025 times
Hi, torsinadoc
The only change I've thought about making to reduce tube currents is to use a reflective insulator on the outside of the tube but I have not done that yet until I find a suitable product.
Lou
Lou
