Solar images 27th May 2021
- Has thanked: 8558 times
- Been thanked: 8290 times
Mark T recently reminded me to take 'critical' image scale into account, matching focal ratio and camera pixel size to achieve the best overall degree of resolution. Taking this onboard for calcium K-line imaging I made a 40mm mask for my 72mm Altair Astro Lightwave with a native focal ratio of f/6.
Objective Mask by Stuart Green, on Flickr
The idea of taking a 72mm objective and reducing it to a 40 mm might seem a waste of glass, but Mark pointed out the additional benefit of reduced spherical aberration.
What a difference!
Here's the result (at 40mm).
20210527_CaK_FD_40mm by Stuart Green, on Flickr
Compare this image taken at 72mm (all processing the same as the 40).
20210527_CaK_FD_72mm by Stuart Green, on Flickr
...and this one which is the same 72mm image with 'optimised' sharpening.
20210527_CaK2_FD_72mm by Stuart Green, on Flickr
Neither of these at 72mm match the 'resolution' of the image taken with the mask when you zoom into the detail. Thanks Mark.
Here it is in colour:
20210527_CaK_FD_40mm_Colour by Stuart Green, on Flickr
I should add that the conditions were average to poor as these were all captured late this afternoon.
I also managed to capture a WL image of the two active regions on my Tecnosky 125.
20210527_WL_FD by Stuart Green, on Flickr
...and in the morning (first thing) I even managed to capture an image of this same region in Ha on the 250mm RCT. Not ideal with the conditions and I failed to take a flat, leaving some residual 'texture' in the background from the camera.
20210527_Ha_RCT_AR2824_AR2826 by Stuart Green, on Flickr
The weekend is looking good weather wise, but of course these active regions are rotating out of view.
Thanks for looking.
What a difference!
Thanks for looking.
- Has thanked: 17853 times
- Been thanked: 16992 times
Re: Solar images 27th May 2021
All of these look really nice Stu. That 40mm mask works!
- Has thanked: 6305 times
- Been thanked: 7323 times
Very good images and an interesting topic, Stu!
Thanks for sharing!
Arne
Thanks for sharing!
Arne
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Stu, yes, it's interesting how masking the objective make's a difference, I couldn't get my head around it at first but the results speak for themselves. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Ivan
- Has thanked: 3483 times
- Been thanked: 2262 times
Hi Stu
This diaphragm works great. The difference was obvious even on the small screen of the phone I was looking at.
Ivan
Ivan
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Nice captures, Stu, and an interesting result of the aperture study in Ca. It makes quite a difference.
Peter
Peter
Very good images, Stu. The results from the reduced aperture test surprised me. Makes sense to me now but does this mean that we should listen to Mark?
Phil
Phil
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Excellent work and mask comparison Stu!!!
Thanks a lot for sharing.
I am struggling with mask-no mask the last days, and did not have the time to make a comparison. (130 mm --> 100 mm).
I will soon after your very useful example!
Alexandros
Alexandros
Alexandros
Greece
Greece
Am I missing something? when I zoom in I see much nicer detail in the 72mm vs 40mm?
That's a beautiful Halpha
- Been thanked: 4427 times
Very nice set of images Stu...great captures
Ha....ha....Yes, I guess so.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Very good imaging Stu the 40mm aperture stop makes a real difference.
Martin
Martin
Many thanks, Alexandra.
Under these conditions and with this processing it appears that the masked image has more of a 'cauliflower' texture whereas the images taken at 72mm are less well defined, even a bit 'dotty'. Will it be the same result under better seeing conditions or with further micro-tweaking of the ImPPG parameters, I'm not sure and it remains to be seen, but I was surprised at the improvement I saw in this example.
- 40mm Mask vs 72mm.jpg (209.51 KiB) Viewed 292 times
