May 27, 2021 AR12824, 12826 WL and Ha
Hi All,
Another decent day for imaging even through thin clouds and haze this morning. No proms, just ARs.
Phil
Phil
Re: May 27, 2021 AR12824, 12826 WL and Ha
Hi Phil,
So well done on your excellent captures showing so much detail of these two AR's before the dive over the edge.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Phil, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9145 times
- Been thanked: 6027 times
- Has thanked: 6181 times
- Been thanked: 7142 times
- Has thanked: 8418 times
- Been thanked: 8165 times
Excellent, Phil. Beautiful images.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Spectacular images, Phil.
What continuum wavelength are you using for the white light images?
How far detuned is your H alpha image (2nd from the bottom)?
Peter
Peter
Peter,
The continuum image was using the unheated etalon so I assume a wavelength of approximately 656nm.
Great observation. To my untrained eye I had not noticed the differences other than processing variations. Etalon temperature was not intentionally changed. During the 13 min. between shots, a focal reducer was added and I had to wait for gaps in the clouds. Maybe that had an effect.
What is your estimation of wavelength shift?
Phil
Phil
- p_zetner
Hi Phil.
I will try the unheated etalon on my next imaging session. It’s a great result.
The off-band H alpha looks like a ~0.5 angstrom detuning. If the etalon was cooling this would be to the blue.
Peter
Peter
Thanks Peter. I will try setting the temp higher next session.
Phil
Phil
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Just amazing Phil!!!
You get so much definition despite the fact that the areas are close to the edge!
And there is also so much 3D impression on your two last Ha. How do you achieve this?
Is the focal reducer that makes the miracle? (apart your experience) What is your train for the last two photos?
best wishes,
Alexandros
best wishes,
Alexandros
Alexandros
Greece
Greece
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Hi Alexandros, and thanks.
No secret ingredients, just focus well, stack, and I use Imppg for the main processing and usually a quick descreening in an image processing program.
Maybe some level or curve adjustments, crop out the edge artifacts, that’s about it. Good luck.
Phil
Phil
- p_zetner
Hi Phil.
Actually your detuning might be smaller. I was thinking in terms of my filter which has a 0.6 angstrom bandpass. I think your filter is narrower? So, it might be a shift on the order of your bandpass.
Peter,
The filter is speced at 0.3A. I’m not sure exactly what I get from it but at about 1angstrom per 9°C, I’ll try a 3° change.
Phil
Phil
- Has thanked: 17581 times
- Been thanked: 16698 times
Very fine views of two departing active regions!
Very nice images, Phil. Thanks for sharing.
- Been thanked: 8794 times
Wow!! amazing images
What model SolarSpectrum do you have?
- Been thanked: 4787 times
Thanks again for the kind words.
Alexandra, the filter I'm using is a Solar Spectrum, Solar Observer SO-1.5 0.3ang. 25mm aperture. It's nice but still needs flats.
Phil
Phil
- Been thanked: 4340 times
These are superb images Phil...very impressive capture and processing
