AR2824 and AR2826 my contribution May 27, 2021
- Has thanked: 9145 times
- Been thanked: 6025 times
Hello all: after seeing all the magnificent images posted, I could not resist not imaging these two sunspot groups before they reach the limb. I took a half hour this morning before work. Seeing was not helping, as we just had a storm last night over southern New England, so lots of humidity in the air and warm weather. I tried using the sodium Quark, as it seems a bit less sensitive to seeing conditions.
- 080117 final color.jpg (983.99 KiB) Viewed 425 times
- 080117 final mono.jpg (752.66 KiB) Viewed 425 times
Re: AR2824 and AR2826 my contribution May 27, 2021
And they turned out great, Franco. I like the sodium.
Phil
Phil
- Been thanked: 8791 times
Very nice to see a Sodium image, we don't get them often
- Has thanked: 9413 times
- Been thanked: 5574 times
Hi Franco,
Excellent close up.
Excellent close up.
- Been thanked: 16694 times
Franco,
I have always liked the Sodium D line images. They often seem sharper and more contrasty than similar continuum images. I read that they capture the transition layer between the Photosphere and lower Chromosphere and adds a bit to the detail seen in continuum. I think Helium gives a similar view.
I hope to see you image in sodium more often.
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Franco,
A great shot and a well-deserved SPOD. Congratulations.
Ivan
Ivan
- Been thanked: 4786 times
Thank you Alexandra, Rainer, James, Ivan and Maurits for your kind words. I was pleasantly surprised the image made SPOD . Will try to use more the Sodium etalon going forward.
- Been thanked: 4340 times
Well done Franco...excellent images
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Well done Franco, congratulations on getting a SPOD , There's some great detail in that Image . What telescope and Camera did you use?
Martin
Martin
Thank you Brian and Martin for your nice comments. I used an Explore Scientific 152mm achromatic refractor and the FLIR Grasshopper 3 174 chipped camera. I shot 40 Gig of data, out of which only 1 Gig was used.
- IMG_3572.jpg (1 MiB) Viewed 338 times
- JochenM
- Been thanked: 1619 times
Nice and interesting capture, Franco. Looks like it worked out great despite the lesser conditions.
Clean looking setup as well.
- Has thanked: 8418 times
- Been thanked: 8163 times
Excellent, Franco. These look great. Congratulations on SPoD.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Great image, Franco, very detailed.
Raf
Thank you Jochen, Stu, Raf and Maurits, greatly appreciated. Currently raining here with no sun in sight for several days…
