Cak and WL 28-05-2021
Martin_S
Has thanked: 999 times
Been thanked: 3060 times
Post by Martin_S »
Today was a day of mixed results. I tested a 5x GSO barlow that I bought last week, it was rubbish , it had a large central reflection that I could not eliminate, so it's going back to the supplier. Next I dropped my Skywatcher Synscan hand controller and it stopped working. So I opened it up and lo and behold it has a Celestron control board inside, I managed to get it working again but only had time for a few images before the atmosphere started to boil. Here are the results.
Martin
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: Cak and WL 28-05-2021
Post by EGRAY_OBSERVATORY »
Well-nice images Martin and lucky the HBX is back working. Not surprised that the PCB is Celestron, but the programming may be down to SW.. :o
Has thanked: 9292 times
Been thanked: 6128 times
Post by ffellah »
Nice images, Martin. If I am not mistaken, SW and Celestron are part of a large Chinese company.
Has thanked: 17925 times
Been thanked: 8891 times
Great images Martin :bow :hamster:
Have you tried adding extra space with the 5x Barlow? My Televue 2.5x Powermate had a terrible reflection in the middle for anything solar. Alfred kindly told me a fix, I had to add an extra 4cm gap between it and the camera chip and it worked, no reflection. However with a Barlow this may change the mag power?
Has thanked: 17813 times
Been thanked: 16948 times
Post by DeepSolar64 »
ffellah wrote: Fri May 28, 2021 10:11 am Nice images, Martin. If I am not mistaken, SW and Celestron are part of a large Chinese company.
Yes. Both are owned by the Taiwanese Synta corporation.
Very nice work Martin!
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Nice images Martin.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Lovely captures Martin, sorry to hear of your less than brilliant day, least you got the hand controller working again, nightmare. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Martin_S
Post by Martin_S »
Montana wrote: Fri May 28, 2021 2:47 pm Great images Martin :bow :hamster:
Thank you for for your suggestion Alexandra, I did a forum search as I did read that thread a while back, the only thing is it gave too many results with the term Barlow. I will certainly give it a try.
Martin
Martin_S
Post by Martin_S »
Thank you all for your feedback. It's most appreciated.
Martin
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Nice set of images Martin :bow
Glad you managed to get the hand control working too!
Martin_S
Post by Martin_S »
Alexandra, it worked, I did have to experiment with a few spacings and insert a small .5 focal reducer in the image train. Here is a test image.
The viewing was terrible today. At least I know I can get a close up of sun spots when the viewing is better.
Martin
WL_085207_lapl4_ap7336 5x cmp.jpg (185.89 KiB) Viewed 287 times
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Looks good, Martin.
Glad to hear you managed to fix the reflection in the barlow. That's a fairly common thing it seems, same thing going on with my 2.5x powermate in some configurations (easily fixable by inducing a minor tilt though).
Jochen Maes
Belgium
https://www.jochenmaes.com
Martin_S
Post by Martin_S »
That might be something to look at in the future JochenM, thanks for your suggestion,
Martin
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Great images, Martin. Looks like you’ve worked through the issues.
Martin_S
Post by Martin_S »
Thanks Stu
