Cak and WL 28-05-2021
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Today was a day of mixed results. I tested a 5x GSO barlow that I bought last week, it was rubbish , it had a large central reflection that I could not eliminate, so it's going back to the supplier. Next I dropped my Skywatcher Synscan hand controller and it stopped working. So I opened it up and lo and behold it has a Celestron control board inside, I managed to get it working again but only had time for a few images before the atmosphere started to boil. Here are the results.
Martin
Martin
Re: Cak and WL 28-05-2021
Well-nice images Martin and lucky the HBX is back working. Not surprised that the PCB is Celestron, but the programming may be down to SW..
- Has thanked: 9144 times
- Been thanked: 6025 times
Nice images, Martin. If I am not mistaken, SW and Celestron are part of a large Chinese company.
- Has thanked: 17667 times
- Been thanked: 8789 times
Great images Martin
Have you tried adding extra space with the 5x Barlow? My Televue 2.5x Powermate had a terrible reflection in the middle for anything solar. Alfred kindly told me a fix, I had to add an extra 4cm gap between it and the camera chip and it worked, no reflection. However with a Barlow this may change the mag power?
- Been thanked: 16693 times
Yes. Both are owned by the Taiwanese Synta corporation.
Very nice work Martin!
- Been thanked: 4786 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Martin, sorry to hear of your less than brilliant day, least you got the hand controller working again, nightmare. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Martin_S
Montana wrote: ↑Fri May 28, 2021 2:47 pm Great images Martin
Thank you for for your suggestion Alexandra, I did a forum search as I did read that thread a while back, the only thing is it gave too many results with the term Barlow. I will certainly give it a try.
Martin
- Martin_S
Thank you all for your feedback. It's most appreciated.
Martin
Martin
- Been thanked: 4340 times
Nice set of images Martin
Glad you managed to get the hand control working too!
- Martin_S
Alexandra, it worked, I did have to experiment with a few spacings and insert a small .5 focal reducer in the image train. Here is a test image.
The viewing was terrible today. At least I know I can get a close up of sun spots when the viewing is better.
Martin
- JochenM
- Been thanked: 1619 times
Looks good, Martin.
Glad to hear you managed to fix the reflection in the barlow. That's a fairly common thing it seems, same thing going on with my 2.5x powermate in some configurations (easily fixable by inducing a minor tilt though).
- Martin_S
That might be something to look at in the future JochenM, thanks for your suggestion,
Martin
Martin
- Has thanked: 8415 times
- Been thanked: 8161 times
Great images, Martin. Looks like you’ve worked through the issues.
- Martin_S
Thanks Stu
