Heya,
Took a last minute stab at AR2824 as it rounds the limb. Also included the previously named AR2825, it still has a visible pore in the region (can be seen both in Calcium & Continuum) but its faculae are much brighter in Calcium. The monstrous AR2826 is out of sight but its still throwing up surge prominences at the limb. AR2824 is still very active despite not looking like a big spot or plage region, it had a huge explosion yesterday that spanned a huge area and it had some loop prominences after words (post CME loops), unfortunately we couldn't see them so easily due to position near the limb. Crazy activity from this one spot! Presented in Calcium today. I used a 2.13mm air gap between the lenses of my C6R refractor and masked it to 120mm F10 and then used a 1.62x barlow on an ASI290MM 2.9um camera for near critical sampling (F18 would have been critical), so close enough for me as this requires better seeing to really accomplish. My seeing peaked around 0.7~0.8 arc-seconds this morning.
The C6R + Air gap re-spacing from Bob's thread here (LINK).
Seeing Conditions:
Equipment:
C6R Refractor with 2.13mm air gap; masked to 120mm F10
2" Baader Blue CCD-IR Block Filter (sub-aperture internal D-ERF)
Lunt B1200 CaK Module
ASI290MM (2.9um pixel) camera
Best 61 frames of 3.2k per image
0.7~0.8 arc-second seeing peaks per SSM
Approximately 0900 Eastern Time from Florida
AR2824 in Calcium K | May 29th 2021
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 17853 times
- Been thanked: 16996 times
Re: AR2824 in Calcium K | May 29th 2021
Very nice CaK Marty.
Beautiful captures Marty and the coloured versions really do show-up the details so well.
Thanks for sharing
Thanks for sharing
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely Cak captures Marty, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Marty,
In time I hope to get me a Celestron 150 or an Astro-Tech AT130EDT. Those would be really nice for high rez work on the solar granulation and would out perform my Celestron 102 during good seeing conditions. The problem is that seeing won't often allow the 102 to be used to it's maximum resolution. Lately I have been a bit lucky though.
My dream scope? A Takahashi TOA150!! But it's big, heavy, expensive and would take a big heavy expensive mount. And an observatory to put it in!
A more practical option would be to get a filter for my old 6"F8 Criterion newtonian. It has good optics and is a good performer.
- JochenM
- Been thanked: 1619 times
Interesting setup and looks like it performs superbly. Very nice fine detail.
Hopefully we'll get some nice proms as a parting gift when this region goes around the bend.
